Jordan
17 -
Reputation
2 NeutralPersonal Information
Location
United States
Recent Profile Visitors
Publish / Export Status Bar
Jordan replied to trashcan's question in Wishlist - Feature and Content Requests
@trashcan 100% agree -
Thanks @StephiPoole! Much appreciated Will see if anyone on my team can help with the Drawing Label tool question - -
I am currently rendering hidden line section (clip cube) viewports in VWX 2021 - it is maddeningly SLOW. From what I've read - everything outside the VP crop is rendering? I generally enjoy using VWX but sheeting views that take 20+ minutes to render make feel insane. It's not functional software. I could have traced the view in illustrator and imported 2D vector lines in the time it has taken me to update a hidden line viewport. Please fix this issue!
Label Preferences or default label style in Viewports?
Jordan replied to Judy Cosgrove's question in Wishlist - Feature and Content Requests
2019 -
Running into this weird thing where the "bubble scale factor" is greyed out and I cannot change this default property of the drawing label. Why is this happening and how do I fix this? -
Sheet Layer Viewport lock position and update
Jordan replied to VincentCuclair's topic in Architecture
Minor emergency - all my sheets in a document have become GREY and everything is locked. WHY??? How do I unlock???? I did not assign anything to a new class!! -
OK = so I created a custom view from a large-ish model and cropped in on it to create the desired view on the sheet layer. Rendering it as Open GL with Hidden line foreground. Taking 5+ minutes to render. Is this a typical render time for something like this? See attached images - note the cropped viewport and the entire model seen with "edit crop" active (for reference). I assume when I press update render - everything is rendering in the model? Not just what I am seeing in the viewport? Any comments or help appreciated - I'm new to VWX OBV!!
Awesome! @barkest Very helpful!
Thank you @JustinVH I am importing lines from Rhino. I am having to convert these lines into polygons to activate the option to "close" them. Before converting to polygons this "closed" box was not appearing. I had to find another thread to learn about line types. LOL
Where is this box??
Thank you so much! -
Where is this???? -
Updating the default drawing label to align to my preferences (when creating viewports) is still alluding me.
Hi Jim - Yes same segmentation appears after exporting to PDF. I have every resolution setting I can find maxed-out highest quality. Still cannot achieve a smooth curve for the modeled part appearing in plan in open GL. See attached viewport/sheet settings.
Related question - re. viewports in 300 dpi sheets and model appearing in design layers with maximum OpenGL quality selected Attached images show curving geo looking good+smooth in the model, and appearing segmented + chunky in plan, 2D on the sheet layer despite 300 dpi and max render quality selected, both open GL. Cannot seem to find an explanation for this - - - can anyone help?
