1,989 -
Posts posted by Jim Smith
On 1/8/2020 at 11:07 AM, Pat Stanford said:
The Wall Heal tool is not required that often any more. The native intelligence of the walls is much better than 20 years ago when the wall and wall heal were added.
The Wall Join and Component Join can be extremely useful to get walls to combine the way you want them to.
Haven't update to VW2020 yet but in VW2019 I'd say yes & no. I still get some glitches such as:
-when a wall that's joined at 90º to another is moved, the plan may look OK but a wall heal reveals the old join is still there on the stationary wall
- using the Join command doesn't always join components or leaves a line in a join at 90º
- some components just don't join properly and so in some cases walls have to be deleted & redrawn or a wall has to be grouped first as a work-a-round so the wall looks correct
Overall, walls in 2019 were very buggy, but that seems to have been fixed in the later SPs
Now if we can only have the Quick Key back that was removed in 2014(?) that allowed one to use a key command to align replacement walls rather than having to use the mouse I'd be much happier.
- 1
While I didn't do a deep dive on the topic, a quick look see on the interweb has many links to "Clipboard" issues. Like you I'd like to know the basis for this. Heck, I'd like to know why electrons, that are constantly in motion are able to "store" stuff in the first place.
Welcome to the forum!
When I used ACAD as my go to software (back when Adam Ant was new & cool), I was always bumping into "rules" as it seems there was only one correct way to do something. In most situations VW allows for multiple ways to approach an end result. As has been pointed out by other (smarter) users above there are some real advantages to using VW. I'd encourage you to kick some of these things out.
My work flow could be called BIM-ish in about 80% of our projects but even then I will sometimes revert to 2D (especially for some quick details).
As a further example: despite many examples, explanations, training & arguments one of our principals continues to do everything in 2D.
With Lines.
Without almost any polygons.
Without Hatches.
As his projects are not part of most other's workflow. No harm no foul, but the reason I use his example is (as frustrating as it is for me to think about) he gets a product to a client & the client is happy and the projects get completed. I might suggest that you work as you feel comfortable, but that you also scratch around the programme to see how much more you can achieve in a more timely manner using the 3D potential of the programme.
- 1
I know it's a matter of taste, but I'd not choose a "Dark Mode" as I spent too many years in front of a black CRT with a glowing green drawing hammering out commands until I discovered MiniCad. Yes, I am THAT old.
I was told years ago that using the clip board between one file & another may introduce minor errors that can lead to file corruptions. The analogy I was given was that using the clip board between files is like a "photo copy of a photo copy". So as an abundance of caution I use either Reference information from another file, or import a symbol as these techniques are designed specifically to import info from one file to another.
I've not installed VW 2020 yet & may get around to it later this month. I am curious if the Dark mode is the only choice or may one keep the it light?
I'm always nervous about Copy/Paste from the clipboard from one document to another. If I want to copy information from one file to another I always make the info I want copied into a symbol, then import the symbol to the new document & then change the symbol to a group & ungroup & delete the symbol.
Back in the pencil & velum days I used an "A-A" convention for sections. Nowadays we just treat a section like any other detail.
For example: 1-303, 2-303 etc. and show a section cut line. I know it adds another line on a document but I take your point about user choice.
On 12/4/2019 at 7:16 AM, shorter said:
Current default is ALWAYS centre to centre. This is only good for internal walls or walls where you have made no dimensional change. Would be good if the Wall were 'smarter' in this respect.
I may not understand your request properly. I change walls all the time & I'm able to select what side the replacement wall is based on the selected wall.
Yeah, by 5pm our christmas lights are on!
ahhhh! I am such a dolt! It just clicked, (pun intended)
Background Setting: OPEN GL
Foreground Setting: Hidden Line
Foreground RENDER Setting: Open & check Hidden line render settings "Sketch Hidden Line Results"
This is even more curious. Printing a PDF without another Viewport stacked overtop results in ALMOST the desired effect. The Sketch is Wireframe not Hidden Line
Weird
To work-around I've had to stack a Hidden Line Sketch Viewport over an Open GL Viewport. I'm going to try a new file and see if this is still an issue...
In this OPEN GL & Sketch no longer play nice in the same viewport. I checked the objects in the design layer, they do have Sketch selected in the Render tab of the OIP. I've used this setting many times & never had an issue, until now.
Oh, & I checked a file that had the rendering option of Open GL with a Sketch hidden line that was created before the SP6 Update and it works as expected.
As can be seen here:
Just updated to the latest 2019 SP (6?) & now when I try and use OPEN GL with a foreground sketch style, it doesn't work...
I'll try a restart & see what is what in the morning
Happy Thanksgiving to all in the USA from your pals who already had ours in October!
@Tim Norman-Prahm Generally we work with a very basic 2D stair in plan in SD & DD, just a series of rectangles on a Layer called "Vert Trans Main". This is a Hybrid 2D/3D Symbol and is used to lock in the space and as the layout develops the stair may morph as required, but we've not spent very much time on all the gadgets in the stair tool only to move it, alter it, make mental gymnastic kung fu moves. As the stair starts to get "locked in" we build a 3D model stair, in a 3D stair class to control the visibility. 3D model starts kinda blocky then gets more refined as required. As we get closer to permit drawings I take a deep dive into classes in 2D to get the look I want on a plan. The 3D model allows me to cut the sections for construction details.
Get out now! It's a trap!
The lesson I have learnt the hard way over these many years is the tool in its many iterations is a time sink so I model my own stairs.
I note on the calendar that Construct Canada (Dec 4-6) Canada's largest AEC industry show (that I attend every year but have no affiliation to) isn't noted. I know that both Auto Desk and Archicad have had booths in the past (Auto Desk isn't a sponsor this year). I seen people I've know from the east coast, Quebec & Alberta at past shows. You may want to add it to your calendar.
@JMR ... or draw a line through the text?😝
Thanks! I've been looking at this box for years & never noted the Visibility button !!!
What a dope!
Maybe there's a way to do this, but from time to time I need a new Layer or Class & either forget to make it visible to all at the time of creation, or a situation changes & want to show this Layer or Class on all (or mostly all) Viewports.
Alternatively I'd like to be able to select several Viewports & turn on a Layer of Class.
Please restore the Keyboard command for Wall Replacements
Posted · Edited by Jim Smith
This is an old request that I can't find on the BB that I want to re-request and as I've not yet updated to VW2020 it may be a moot request.
In past interactions of VW prior to VW2014 (?) one could align replacement walls by using the keyboard to choose where one wanted the replacement wall to align, right, left, centre etc. and this function has never been added back. For those who didn't use it, it was similar to what happens when one uses the Align command. Here's what I mean:
Align command allows one to us a keystroke to choose alignments of object chosen:
Unless I'm missing a setting, no amount of moving my facial features allow me to do the same thing with replacing walls I have to move the mouse to the dialogue box and choose my selections with mouse clicks:
