MartynHowes
    8
Reputation
3 Neutral
Personal Information
  • Location
    United Kingdom
Recent Profile Visitors
  1. Hi, we are having this same problem with VW2020 after SP2. The annoying thing is that the problem persists when saved back to a VW2019 file and there is seemingly no way to fix this. This has now affected around 10 of our most recent projects which is hugely frustrating. Furthermore I tried to download the workaround above and the link is no longer active. Is everyone else still having this problem and is there something that can be done about it? Martyn
  2. Hi VW hive, I have been asked to add a column within the window schedule worksheet that details the wall style that the windows sit in. i.e. Window W01, 1000mm width, 1400mm tall, First Storey, Sash opening, Wall type 5 Has anyone done something similar to this? I have added a column that recalls "WallTypeName" (function) but the output is always '#TYPES!' (see attached image) I am possibly (probably) missing something obvious here but I can't find an alternative output that would list the wall types that the windows are in. Could someone please help :)
    Awesome job. It would be amazing to have this feed in to the standard Door Schedule but I can see the problems in creating this. Also I second the other comment, panel, jamb and frame dimensions would be great to tweak. Cheers
  3. Hi all, Does anyone know of a way to add a further column to the 'Navigation - Sheet Layers' Palette? I was hoping to display the revision data alongside the sheet number, as it is not immediately obvious what revision status each sheet has without going through settings etc. Many thanks :)
  4. Hi Josh. Did you get a fix for this issue? I have created 3 site models recently that have all had this same problem. It's a little frustrating
  5. Sorry about that post, I just wanted to see what would happen if I attached something. Now I don't know how to delete it haha! My ineptitude could exceed the file size!
  6. Hi, sorry where are the files as attached? I often see this problem and don't understand where to download the files as referenced? Cheers
