pdrake2126
    36
Reputation
1 Neutral
Personal Information
  • Location
    United States
Recent Profile Visitors
  1. yes, i've found lots of things not working correctly. the data bar bug seems to be one of the most annoying. the lack of response is also troubling. (note, this is my very polite voice.)
  2. I have this same problem with 2017 and 2018 (way worse). There should be no reason for this with my system. Attached are my system specs which also include a Quadro M5000. So far, no help from tech support that i pay for.
  3. i'm having redraw issues and am wondering if i do not have my video setting configured correctly. every time i do anything in vectorworks the software screen goes black and then redraws all the palettes, sometimes more than once. is this a known issue? vw 2017 sp2 build 338823 video card: nvidia quadro M5000 machine specs attached:
  4. nevermind, found it. in the OIP check "draw 3D only". this allows rotation and keeps the truss editable.
  5. hello, can anyone tell me how to change the hanging angle of a curved truss so i can make an arch? there is no field for it in the object info box.
  6. i see that you can specify fullness in the soft goods palette. i don't see any info on finding out a way to output the length and other info once the fullness is set. can anyone help with that or point me to a tutorial i can learn how to do it? thanks
  7. it's a rectangle. 16" x 8" when i select the rectangle there are handles, when i select the reshape tool, there are handles, when i switch to "add vertex mode" the handles go away. when i switch back to just reshape the handles appear. when i move one and switch to add vertex mode the handles stay visible and i can add a vertex, but not until i move one. hope that makes sense.
  8. it works after i move a vertex, but until then no handles.
  9. not sure what happened, but the reshape tool has become finicky. i don't even get handles when i select the "add vertex mode". anyone have any ideas if a setting changed?
  10. thanks, that was it. you now need to download those.
  11. windows, in previous versions it was in the default folder.
