fabrica
309 -
Posts posted by fabrica
you had no sash selected on other window - change to sash and it works:
- 2
can't install it! UPDATE: I must read the instructions first !
VW2024 , Mac 14.3
41 mins for the redshift render is just dreadful.... and so far away from the quality of the corona render its not worth a comparison.
(I confess I do use corona also and would only use shaded render in vectorworks for quick early stage views)
If you want photorealistic/high end it's off to corona or twinmotion you go....
- Popular Post
- Popular Post
either extrude along path or the wonderful plug-in from AF-Design: https://plugins.andreafacchinello.it/baseboard/
- 5
yes - all fine so far
@Kevin McAllister I put a few similar tools together (long click to open) to shorten the top bar ...
- 1
draw a polygon around your walls , then AEC Menu -> Convert Objects from Shapes ... choose slab and your done!
@Chris Fleming maybe look at twinmotion ?
- 1
for me, I would do the following:
- in your editor of choice (affinity, Pixelmator etc) , I would overlay the ambient occlusion (at 90%) onto the base colour and export as 1 image.
Then add this image to the colour slot - change OBJ Attribute to -> image
Not 100% sure but don't think Vectorworks can handle normal or height maps. (so no need for them)
If you need to scale image you have to use the absolutely useless 'set by image' button ..!
If you are only using 'shaded' render that's all I'd do...
- 1
make them symbols and auto hybrid....
https://app-help.vectorworks.net/2017/eng/VW2017_Guide/Shapes3/Creating_Auto_Hybrid_Objects.htm
- 1
12.45
14" Macbook M1 Pro, 32GB
13.2 ; VW 2023.SP.3
sorry, just seen you were after hatch ! not a texture………
used to have more - but this is all I could find!
save, quit and restart vectorworks gets rid of them.... (probably not the answer you wanted!)
- 2
sounds related to this: (the workaround is to select the wall and move it 0,0 - this will regenerate wall)
Cabinet Tool - heights grayed out
in Architecture
Posted
click the calculator looking icon first !!
