MullinRJ
2,017 -
Everything posted by MullinRJ
NO! - You have to memorize all of the constants! What kind of programmer do you want to be? Spoon fed?!? Seriously, here are a few: kResetEventID = 3; kObjXPropPreference = 4; kObjOnInitXProperties = 5; kObjXPropHasUIOverride = 8; kObjXHasCustomWidgetVisibilities = 12; kObjXPropAcceptStates = 18; kObjOnObjectUIButtonHit = 35; kObjOnWidgetPrep = 41; kObjOnAddState = 44; Yes, there is a file in the SDK. You should download a copy if you haven't already. I'll see if I can give you a file name in a minute. Raymond
Michael, I'm not Josh, but I do have an example straight from the horse's mouth. { From VCOR, posted by Charles Chandler Jan 2007, updated 20 Dec 2015 } PROCEDURE Example3; CONST kResetEventID = 3; kObjOnInitXProperties = 5; kObjXPropHasUIOverride = 8; kWidgetButton = 12; kObjOnObjectUIButtonHit = 35; buttonID_1 = 1234; {user-definable index} VAR result :BOOLEAN; sourceFieldNumber :INTEGER; buttonEventID :INTEGER; theEvent, theButton :LONGINT; thisDoesNothing :LONGINT; displayString :STRING; BEGIN vsoGetEventInfo(theEvent, theButton); CASE theEvent OF {User has single-clicked the object's icon.} kObjOnInitXProperties: { 5 } BEGIN {This tells VW to let the object decide what goes onto the Object Info palette.} result := SetObjPropVS(kObjXPropHasUIOverride, TRUE); {Now we manually add the "normal" parameters...} {One way is to use this single call to add all of the existing parameters.} result := vsoInsertAllParams; {Alternatively, you can use this to tack individual parameters onto the end of the list one at a time. This way, you don't have to use SetParameterVisibility in the reset event to hide parameters that you never want to see.} sourceFieldNumber := 1; displayString := 'My Great Field Name'; result := vsoAppendParamWidget(sourceFieldNumber, displayString, thisDoesNothing); {Finally, we add the button.} displayString := 'My Great Button'; result := vsoAppendWidget(kWidgetButton, buttonID_1, displayString, thisDoesNothing); END; { 5 } {User has clicked a button in the Object Info palette.} kObjOnObjectUIButtonHit: { 35 } BEGIN CASE theButton OF buttonID_1: BEGIN AlrtDialog('Custom Button Dialog'); END; END; END; { 35 } {Object reset has been called.} kResetEventID: { 3 } BEGIN Rect(0, 1, 1, 0); { draw a square } END; { 3 } END; { CASE } END; RUN(Example3); Never go on an Event Enabled Trip without directions from Charles Chandler. It looks better with the keywords color coded in my text editor. Have fun, Raymond
Hidden records, or visible ones for that matter, don't need to be attached to anything. You can add fields dynamically, store your data, and retrieve it at any time, even the next time the file opens (assuming you saved it first.) As to the number of fields a record can handle, I never looked for the limit. I have successfully stored 10K unique fields in one record as a test. I assume the upper limit is 32K fields, if I were to guess. Maybe someday I'll ask myself that question again and try to answer it. Records are excellent for storing data that persists in your file, but not ideal for data that needs to be accessed by other files, though I've done that with much effort. If you want to read and write from a central source so multiple files have access to it, I suggest you explore using XML. Whether you use records or worksheets to store your local data is a personal choice. Good luck, and have fun doing it, Raymond
Hello David, When you do get up to, or beyond VW 2016 (where the WS functions were introduced) you will have to use "=RunScript() instead of "=Run(), as I see in your screen shot. Raymond
@Eric Mousse , I bit the bullet and updated the Wall Openings plug-in object for VW 2020. This was not a trivial exercise which is probably why nobody has done it yet. The code is unlocked so you or anyone else can build on it. When you add it to your workspace, it will be in the "panta rhei" category*. All I ask is that you drop me a line in a week or two, after you've played with it a bit and let me know how it's working for you. If there are any glitches, especially if I've caused them, I'll help you iron them out. Wall Opening.vso.zip Have fun, Raymond * Hello, Petri.
Replacement command for deprecated SetWallHeights()
MullinRJ replied to MullinRJ's topic in Vectorscript
Pat, Julian, Thank you both. Julian, that is indeed the command I was looking for, but it does not work out of the box. On my first attempt using this function my initial excitement was quickly dashed when — nothing happened. Then I reread the thread Pat posted. At the end of his example script he included a ResetObject() command. Together these commands make the wall display as expected, but there was still something missing. Even after the wall height is set at either end, the HEIGHT parameter in the OIP does not update to reflect the change. I don't know if this is normal or not, but it didn't feel right to me, so I dug a little deeper. I drew two walls of different heights in a blank document and exported the file as VectorScript. The wall heights are set with ObjVars 604 to 607, which are marked as "Not for public use" but they work just fine if you don't tell anybody what you are doing, and you convert everything to mm first. These commands are followed by SetObjectStoryBound(), which sets the OIP fields HEIGHT and TOP OFFSET. Though I am still not fluent in Wall terminology, I feel much better with the output of these combined commands. Here's a small function I put together. I hope it helps someone get past these small hurdles. It should be pretty easy to modify this script to also set the bottom elevations of the wall, if needed. Comments and criticisms are definitely welcome. function SetWallHeights1(H :Handle; StartHt, EndHt :Real) :Boolean; { Set the wall height at the beginning and end of a straight wall and update the OIP. } { Return TRUE if the function works, FALSE otherwise. } Var B :Boolean; Begin B := SetWallCornerHeights(H, StartHt, 0, EndHt, 0); if B then begin SetObjectStoryBound(H, 0, 0, 0, '', 0); { affects OIP Top Offset } SetObjectStoryBound(H, 1, 0, 0, '', max(StartHt, EndHt)); { updates OIP Height } ResetObject(H); end; { if } SetWallHeights1 := B; End; { SetWallHeights1 } A little be of Pat, and a little bit of Julian, makes the world go round. Thanks, guys. Raymond -
Thanks, Pat. I tried setting that ObjVar, but nothing happened. When I looked it up I saw it is READ ONLY. It seems strange that SetWallHeights() very easily set the wall's height at its beginning and its end. Why would a command like that be removed without another to take it's place? And if one did take it's place, it would be nice to see a note along with the deprecation notice showing which command to use in its stead. This short script achieves the look of the wall that SetWallHeights() produced, but the Wall Height in the OIP remains unchanged, which doesn't feel right. Is this the way to go? PROCEDURE xxx; procedure SetWallHeightsN(H :Handle; StartWallHt, EndWallHt :Real); { Set the wall heights at the beginning and end of a straight wall. Prior peaks are removed. } Var P1, P2 :Vector; Begin ClearWallPeaks(H); GetSegPt1(H, P1.x, P1.y); GetSegPt2(H, P2.x, P2.y); AddWallPeak(H, 0, StartWallHt); AddWallPeak(H, Norm(P2-P1), EndWallHt); End; { SetWallEndHeights } BEGIN SetWallHeightsN(FSActLayer, 8', 9'); SysBeep; END; Run(xxx); Comments welcome. Thanks, Raymond -
What is the replacement for VS command SetWallHeights()? The DevWIKI documentation says "See architectural category for replacement". So I went to Objects - Architectural and of the 125 commands listed absolutely nothing looked even remotely similar. In the Objects - Wall section, WallPeak() looks like it could be made to function to set a "peak" at the end of the wall, but it is a MiniCAD 4 command and it doesn't seem like it would be the replacement for a command deprecated in VW 2012. I assume I'm missing the obvious, so any help would be appreciated. Thank you, Raymond
Convert Nested Symbols to Groups
MullinRJ replied to Pat Stanford's topic in Resource Share - Vectorscript
Hello Rex, Try this script on for size. It is a little different from the script Pat posted, and only works on selected objects on a drawing layer. Select everything you want flattened (i.e., Groups and Symbols) then run the script. Please try it on a COPY of your data first to determine its efficacy. PROCEDURE FlattenSymsInGroups; { Flatten selected Symbols, and Symbols inside Groups. } { 15 May 2020 - Raymond J Mullin } { BE CAREFUL: } { Use on a copy of your file first to determine if this script does what you want. } { Always wear a mask. This script does not Social Distance in GROUPS. } function FlattenNestedSyms(H :Handle) :Boolean; Begin if (GetTypeN(H) = 15) then SymbolToGroup(H, 2); End; { FlattenNestedSyms } BEGIN ForEachObjectInLayer(FlattenNestedSyms, 3, 2, 0); { Vis & Selected, Deep, Active Layer } SysBeep; { Beep when done } END; Run(FlattenSymsInGroups); HTH, Raymond -
You're welcome, Rex. When a symbol only has simple objects inside, like Lines, and Circles, and Squares (oh my), you won't see the dialog box because there is only one way to decompose it. But if there are nested symbols and or Plug-in Objects inside, then you'll get the dialog asking you how to proceed. Do you want to preserve nested symbols, or flatten everything? If you pick the first option, then you can reselect objects after the operation and proceed "delicately". If you pick the third option, it's like you hit everything with a sledge hammer and everything comes out crumbs – or Lines, and Circles, and Squares (oh my). Essentially, VW is looking inside your symbols first and only presenting you with the dialog if it will change how they get converted; otherwise it converts everything to primitive shapes, no questions asked. If your symbols only have one primitive object in each of them, then you won't get any groups, just the primitive objects. Symbols containing two or more objects will convert to groups. HTH, Raymond -
Hello @rexwexford, I am not sure how you are determining if the script works or doesn't, but it is working on my machine in VW 2020. That said, this is a weird script in that it does not convert symbols on the drawing to groups, but it does convert some nested symbols inside the symbols that are on the drawing to a group, but it does not convert ALL nested symbols to groups. I think it would be more thorough if it used option "2" (Convert all subobjects) in the SymbolToGroup() command. Currently it uses option "1" (Convert plug-in and symbol subjects). But even with this change, the net result would be you still have symbols on your drawing, AND, your symbol definitions may have been modified. If you want to flatten your drawing, or just a selection of your drawing, why don't you use the VW menu Modify > Convert > Convert to Group (CMD-K)? You will be presented with a dialog box where the third option is "Convert all sub-objects". The net result will be that all your selected symbols will be flattened to Groups, and none of your symbol definitions will be modified. This is a much safer scenario, in my mind. If you don't want the symbol definitions intact, after you flatten everything to your liking, you can copy everything to a new drawing. This way you can always go backwards if you need to,. If you use the above script and save your file, you may do irreparable damage; and as Pat warns – {Use at your own risk. May cause pimples or hysterical blindness} If you are looking for something that is not addressed here, please write back. HTH, Raymond -
Hello @Eric Mousse , As @Peter Vandewalle stated explicitly, and @Pat Stanford implied, the dialog needs to be rewritten from the ground up. It is not a simple case of substituting old commands with new ones as I originally hoped. This is not something terribly difficult for a seasoned VS programmer, but may be a bit daunting for a novice. I'll take another look at in the next few days, but if someone beats me to it, that's okay, too. You may want to try your hand at it and feel free to write back with questions. Scripting is an incredibly powerful tool. The more you master the more freedom you have to apply your craft. Raymond
Hi Julian, Do you mean something like this? PROCEDURE xxx; CONST CR = chr(13); VAR H :Handle; BEGIN H := FLayer; while (H <> nil) do begin if (GetObjectVariableInt(H, 154) = 2) then AlrtDialog(concat('Sheet # = ', GetLName(H), CR, 'Sheet # [Title] = ', GetObjectVariableString(H, 162))); H := NextLayer(H); end; { while } END; Run(xxx); By Export, do you mean write to a file? If not, how to format it? Raymond
Hello @Eric Mousse , Assuming the original code used Modern Dialogs and not Classic Dialogs, this list may help if you want to do the edits yourself. You'll have to look up the syntax in the Script Function Reference (found in the VW application folder VWHelp>Script Reference folder) or the online Developer WIKI (link is at the top of this page.) Old VS call New VS call DelChoice RemoveChoice GetChoiceStr GetChoiceText GetField GetItemText GetSelChoice GetSelectedChoiceInfo InsertChoice AddChoice ItemSel GetBooleanItem NumChoices GetChoiceCount SelChoice SelectChoice SelField SelectEditText SetField SetItemText (editable text) or SetControlText (static text) SetHelpString SetHelpText SetItem SetBooleanItem SetItemEnable EnableItem SetTextEditable EnableTextEdit Take note: Some calls just add the DialogID to the parameter list, while others also change the parameters around a bit. Making the edits typically isn't very hard, just tedious. Let the error reports from the script compiler be your guide. Feel free to write back if you have more questions. HTH, Raymond
Ain't programming fun? Glad you got it working. Raymond
@sully8391 , In the Script Editor window, when I have "Language: VectorScript" selected I get this error: Line #1: vs.Message('Test Tool') | { Error: Identifier not declared. } When I have "Language: Python Script" selected, the script runs as expected. This is in a Script Palette script, and in a Tool Plug-In. Also, check in a word processor for any hidden characters in your one-line script, or select all, delete, and retype the line again. One hidden character will crater the simplest of code. Good luck, Raymond
Sorry Sam, When I originally modified that routine to show the error numbers after the text, I added Error 8 because that is what VW was returning when I purposely misspelled my file name. I was expecting Error 6, but I got 8, so I duplicated the error text and added the word "still" so I would recognize the difference. I did not expect to ever share this code, and then you asked. When you mentioned Error 8, and I reread the message "The file ... is still not found", I remembered what I had done. It works for me, but it isn't sanctioned by any accepted authority. You should get an VWI engineer to confirm the meaning of Error 8. My topical search of the SDK did not turn up a list of File IO Error Codes. Raymond
Found it sitting in plain view. The example came from the Script Function Reference - GetLastFileErr() command. Were you looking for something else? Raymond
Sam, I got these text alerts from an example somewhere and added the numerical error codes to the output. If I find the source, I'll post back. errorCode := GetLastFileErr; if (errorCode <> 0) then case errorCode of 2: AlrtDialog(concat('The file "', FName, '" cannot be processed because the hard drive is full. (', errorCode, ')')); 4: AlrtDialog(concat('End Of File "', FName, '" reached prematurely. (', errorCode, ')')); 5: AlrtDialog(concat('The file "', FName, '" is locked. (', errorCode, ')')); 6: AlrtDialog(concat('The file "', FName, '" is not found. (', errorCode, ')')); 8: AlrtDialog(concat('The file "', FName, '" is still not found. (', errorCode, ')')); 10: AlrtDialog(concat('The file "', FName, '" is currently in use by another program. (', errorCode, ')')); 13: AlrtDialog(concat('The file path "', FP, '" does not exist. (', errorCode, ')')); otherwise AlrtDialog(concat('The file "', FName, '" has encountered an undetermined error. (', errorCode, ')')); end { case } Where variables FName, and FP are strings, representing the File Name, and File Path respectively. Raymond
Wow. I didn't really sleep all that well, or walk on the beach, or have breakfast (nice or otherwise). And what cup of tea? Glad your vision is clearing. 8-) All the best, Raymond
Hi Michael, In the second text object of my example, which is derived from your example, I/you use: TextJust(2); TextVerticalAlign(2); { Vert Top Baseline Aligned TextVerticalAlign(2) }{ I think this one has a bug } which translates to CENTERED, and TOP BASELINE. That is exactly where the text is getting inserted. Are you not seeing this? The line in the picture is at Y=0. Raymond
Michael, You are right, but the point I was trying to make is that when you apply a TextStyle, there are two ways to do it – 1) keep the insertion point fixed and move the text block relative to the insertion point (as is done with SetTextVerticalAlign), or 2) keep the text block fixed and move the insertion point relative to the text block (as is done with SetTextVertAlignN). VW uses the latter method of adjusting the Vertical Alignment when a TextStyle is applied. You were probably expecting it to use the first method. I believe your confusion exists because your example does not show enough detail to see what is really happening with the vertical alignment settings. SetTextVerticalAlign() and SetTextVertAlignN() both work perfectly, but you need more than one line of text to show the difference between "Top Baseline" and "Bottom Baseline" settings. When there is only one line of text, the TOP and BOTTOM Baselines (of the text block) are the same, since the ONE line of text is both the TOP LINE, and the BOTTOM LINE. With two or more lines in a text block, the TOP and BOTTOM Baselines are different. The following example should show the difference. I modified your second code example to create multiple (2) lines of text, not one. Now when the Vertical Alignment is set you should see a difference for all five vertical alignment values. Forgive me if I removed too many blank lines. Procedure Test; CONST kVTopTextStyle = 'V Top Text Style'; kVTopBaselineTextStyle = 'V Top Baseline Text Style'; kVCenterlineTextStyle = 'V Centerline Text Style'; kVBottomBaselineTextStyle = 'V Bottom Baseline Text Style'; kVBottomTextStyle = 'V Bottom Text Style'; kString = 'Text Style: '; CR = chr(13); VAR h : HANDLE; s : STRING; BEGIN { Create 5 Text Styles. All Left Justified with the same font, font size, and face. } TextFont(GetFontID('Arial')); TextFace([Bold]); TextSize(24); TextJust(1); TextVerticalAlign(1); { Vert Top Aligned TextVerticalAlign(1) } h := CreateTextStyleRes(kVTopTextStyle); MoveTo(0, 0); BeginText; Concat(kString, CR, kVTopTextStyle) EndText; SetTextStyleRef(LNewObj, Name2Index(kVTopTextStyle)); { ******************** } TextFont(GetFontID('Arial')); TextFace([Bold]); TextSize(24); TextJust(2); TextVerticalAlign(2); { Vert Top Baseline Aligned TextVerticalAlign(2) }{ I think this one has a bug } h := CreateTextStyleRes(kVTopBaselineTextStyle); MoveTo(40', 0"); BeginText; Concat(kString, CR, kVTopBaselineTextStyle) EndText; SetTextStyleRef(LNewObj, Name2Index(kVTopBaselineTextStyle)); { ******************** } TextFont(GetFontID('Arial')); TextFace([Bold]); TextSize(24); TextJust(3); TextVerticalAlign(3); { Vert Center Aligned TextVerticalAlign(3) } h := CreateTextStyleRes(kVCenterlineTextStyle); MoveTo(80', 0"); BeginText; Concat(kString, CR, kVCenterlineTextStyle) EndText; SetTextStyleRef(LNewObj, Name2Index(kVCenterlineTextStyle)); { ******************** } TextFont(GetFontID('Arial')); TextFace([Bold]); TextSize(24); TextJust(1); TextVerticalAlign(4); { Vert Bottom Baseline Aligned TextVerticalAlign(4) } h := CreateTextStyleRes(kVBottomBaselineTextStyle); MoveTo(120', 0"); BeginText; Concat(kString, CR, kVBottomBaselineTextStyle) EndText; SetTextStyleRef(LNewObj, Name2Index(kVBottomBaselineTextStyle)); { ******************** } TextFont(GetFontID('Arial')); TextFace([Bold]); TextSize(24); TextJust(2); TextVerticalAlign(5); { Vert Bottom Aligned TextVerticalAlign(5) } h := CreateTextStyleRes(kVBottomTextStyle); MoveTo(160', 0"); BeginText; Concat(kString, CR, kVBottomTextStyle) EndText; SetTextStyleRef(LNewObj, Name2Index(kVBottomTextStyle)); END; RUN(Test); HTH, Raymond
Michael, You are seeing the effects of SetTextVerticalAlign() vs SetTextVertAlignN(). My guess is you want SetTextStyleRef() to use the former and SetTextStyleRef() is using the latter, so the text does not move when you apply a TextStyle, but the text insertion point does move, as it is supposed to. You would be better off not using Text Styles and forcing the attributes you want manually. Raymond
The indices are assigned when new names are created, either manually, or when a script runs. When names are deleted they create a void in the list and the indices may be reassigned as new names are created. I would not try to predict the method. Just use Name2Index() to get the RefID of the TextStyle (or other named resource). It should be good until you delete that name or reopen the file. Raymond
Michael, The names of the text styles are kept in the Name List, which is a list of all the unique names in the document, except the layer names. Like class names, object games, script names, their index number reflects their position in that list. Name2Index() returns the number associated with a name in that list, and can be expected to be different in every file. HTH, Raymond
