1,191 -
Everything posted by Sam Jones
I have an event aware point object that that has a drop down list of vendors. When a user changes the vendor name there are 2 other drop down menus that change the contents of their list based on the value of the newly selected drop down. When the user changes a vendor value in an already placed instance of the PIO, all goes according to plan. The vsoStateGetParamChng() function yields points to the vendor as having changed; I query the value, and I then change the lists in the other drop down. Is there any way to get this functionality in the default OIP dialog that comes up when selected in the mode bar. Currently, changing the vendor value in the default OIP does not tell any part of the code that the vendor parameter has changed, there seems to be no way to then change the lists in the drop downs of the default OIP. Is there a way to do that?
Super.
Using vectorscript, how do I import a linestyle contained in the shipping Vectorworks libraries, say "ISO-02 Dashed"? Expanding, how do I access Vectorworks libraries of all kinds in VS? Bite off as much as you have energy for. As always, TIA. Sam
Why inevitable? There are other downsides to python. I must confess that I hear about them second hand, but if true, I'm never going there.
Additionally, I missed using ResetObject on the dimension before ending the PIO code with ResetObject or ResetBBox. As you said, mandatory. Didn't think of it. Probably needed in other object in object scenarios.
I'm looking at object variable 44 all day. Totally missed the possibility of 43. Just when I thought I was getting better at searching the Function Reference.
This is a big problem for using dimensions in VS. I can get the dimension value text to the center between ends by using the calculated position, but I need to align the dimension text with the dimension line. Dimensions below an object shove the dimension text into the object and it is important that the dimensions on all sides look the same in text style and spacing. This is not possible if the text cannot be aligned to the dimension line. This has the potential of scuttling the automation of this graphic.
Not a big concern or rocket science, but I like to avoid the collecting global value, saving value, changing value, do operation, change value back collection of calls.
I was afraid that was the answer
Thank you @Pat Stanford and @C. Andrew Dunning for the line style help. Works like a charm. I would like to set the text size of a dimension that I create inside a PIO. I draw the dimension with: LinearDim(x1, y1-(bayDepth/2), x1-offsetLft, y1-(bayDepth/2), 0, 0, 771, 770, 0 ); I would like to set the size of the text in that dimension object to 2. I attempted to do this with the following line: SetObjectVariableReal(LNewObj, 17, 2); Nothing changed. I can replace the "2" with any value and still nothing changes. Hopefully there is a way to control the text size of a dimension created in a PIO. Thoughts ? Sam
Is there a way to get the line style index number from a name of the line style in VS? I both want to set the line style for an object and I want to set the line style for a class, but both call require and index and I only have a name. Is there a way to define a line style in VS, setting its name and index, or setting the name and getting the index? As always, TIA.
Quick answer: At the beginning of the kResetEventID
Assuming that "BooResult := GetCustomObjectInfo(PIOName, PIOHan, PIORecHan, PIOWallHan);" has been run before the "CASE TheEvent OF", the PIOHan is NIL during the kObjOnInitXProperties event and the PIORecHan won't recognize the 800 constant. So the question becomes where to put the "SetObjectVariableBoolean(PIOHan, 800, TRUE);".
I have a point PIO that has a CreateText() command in it. When it is placed, the document font and text style chosen in the Text menu are used. All well and good. I would like to be able to select existing instances of the PIO and choose a new font and text style from the Text menu and have those selected instances use the newly selected font and text style for the CreateText() procedure in the Reset Event. I have seen other PIOs do this, but currently instances of my PIO will not. There are no text formatting procedures in the PIO code except for some alignment procedures. How can I get my PIO to respond to the text formatting selected. 😁 😁
How to use label legend in one viewport not the other?
Sam Jones replied to hollyyjackson's topic in Entertainment
I don't think there is a way to do what you want. Label Legends (LLs) are linked to the Lighting Device instance they report on, and you can only assign one LL to a Lighting Device. You can turn on and off class visibility of LL fields on a viewport by viewport basis. Thiscan make one LL do the job of two by allowing one field to be placed on top of another (or elsewhere), but you won't be able to put the same field in 2 different places in the same LL. You can copy field values to other fields (usually user fields) and you can create your own custom fields. These options will usually achieve the functionality of multiple LLs. -
Would anyone be up for an object-building "challenge"?
Sam Jones replied to SamIWas's topic in Vectorscript
We're all interested. Like @C. Andrew Dunning I don't have the band width because of my own projects, and that may be the rule here, which is too bad. We would all love to see what others have figured out, and even share some cool tricks. You may get comments on the code you post, and maybe we can have a good discussion around that code that includes are own code snippets. I hope I'm wrong, but a serious go at the picture above would be daunting, interesting, but daunting. Hopefully, @michaelk, who is an excellent VS drawer, or @PatStanford who loves the puzzle will jump in, but again, bandwidth will handicap a serious VS attempt to make a PIO out of that drawing. Here's hoping. -
Nope. The functionality is part of a general plug-in to place accessories. The plug-in is one of over 100 plug-ins/scripts that make up AutoPlot Tools for Spotlight, www.autoplotvw.com. The tools have a 2 month fully functional trial period. If you want to Zoom, I can walk you through using any of the plug-ins.
The parent of what, and do I want the parent to be nil when I select the PIO in the palette in order to suppress the StrDialog? Prior to the event Case test I have the following lines BooResult := GetCustomObjectInfo(PIOName, PIOHan, PIORecHan, PIOWallHan); vsoGetEventInfo(TheEvent, EventMessage); At the beginning of the ResetEvent procedure I set the IsNew variable with IsNew := IsNewCustomObject('RG Grid Marker'); In the ResetEvent procedure I draw the graphic and then have the following test: IF (IsNew & (GetParent(PIOHan) = NIL)) THEN {Post the StrDialog()}
I have a point PIO, that puts up a StrDialog() to ask a question when the PIO is inserted. This is triggered in the Reset Event and only triggered if the PIO instance is new. Unfortunately, The StrDialog is triggered when the PIO is selected in the tool Palette and then triggered again when when the first instance is placed. After that, the StrDialog correctly only appears when a PIO is placed. If I select another tool, the problem reappears when the PIO is again selected in the tool palette. Is there a way to differentiate the time when a point PIO is selected in the tool palette, from when it is placed in the drawing? As always, TIA
Why Doesn't VW Render the Beam Angles Correctly
Sam Jones replied to User-B's topic in Entertainment
He doesn't mention it enough. BeamViz is an absolutely amazing plug-in. It vastly expands the ability to visualize and manipulate light beams and integrates with Spotlight Lighting Devices seamlessly. Get this plug-in; it will blow you away. The downside/upside to this tool is that there is so much functionality you need to take some time to explore it all. -
Prior to 2024, to encrypt a plug-in, I would open the Plug-In manager, select the plug-in, be sure the caps-lock key was activated, and double click on the plug-in name in the Plug-In manager. When I do that in VW 2024, I get this alert. What do I do to encrypt a plug-in?
In a simple command, the code below will return the plan rotation of a VW drawing. PROCEDURE GetPlanRotation; VAR PlanIsRot :BOOLEAN; PlanRot :REAL; BEGIN PlanIsRot := GetPref(92); PlanRot := GetPrefReal(93); AlrtDialog(CONCAT('PlanIsRot = ', GetPref(92), ', PlanRot = ', GetPrefReal(93))); END; RUN(GetPlanRotation); Below are the first 8 lines of the code for an event aware PIO CurrClass := ActiveClass; GetVersion(Major,Minor,Maintenance,Platform); GetUnits(Fraction,Display,Format,UPI,UnitName,SquareName); result := SetObjPropCharVS(kObjXPropShowPrefDialogWhen, '0'); PlanIsRot := GetPref(92); PlanRot := GetPrefReal(93); AlrtDialog(CONCAT('PlanIsRot = ', PlanIsRot, ', PlanRot = ', PlanRot)); The alert below is always returned no matter what the plan rotation is. PlanIsRot = FALSE PlanRot = 0 Is there a way to retrieve the plan rotation from within the code of an event aware PIO?
