Laura Stone
120 -
Calendar
Everything posted by Laura Stone
Will this include the OzCad railing/fence tool that sends to surface and allows the top rail to be below the top of the uprights?
I'm trying to draw a fence on a slope, but once over a certain gradient the top rail of the fence flips to vertical position. Looks like a bug to me. Laura fence rail flip.vwx
Working on a drawing that already had landscape areas, all of the new ones I draw (or convert from shapes) have a square attached to them in top/plan view. It is not visible in other views. I have used different landscape areas, including ones I used before in this drawing without any issue, and get the same result. I can't select the landscape areas by their edges or fills, they can only be selected by selecting the attached square. Anyone have any idea why this is happening? Thanks Laura
And if I export only the trees and uncheck 'export site model' they export at the correct height, but only from the new file. Laura
And another update, if I export the site model as well the trees export at the correct height. But I don't want to include the site model in my IFC file. Laura
Update on this, double checked the trees and they are displaying z=0 in the OIP but they are actually at the correct height in VW. Then when exported to an IFC file they all drop to zero. Laura
Hadn't seen those before, I usually import things from sketchup files on 3D warehouse. We use generic low-polygon trees for models but have given up on shrubs. It depends what the other disciplines are going to do with them. Laura
I have exported existing trees to IFC with no problem in the past but having issues with a particular file. If I try to export the trees I get an empty IFC file. If I copy and paste the trees into a new file they export with no issues but they are all at z=0 If I paste the site model into the new file the trees do nothing when I send them to surface. Anyone have any ideas? Thanks Laura
As far as I know IFC only supports modelled plants, not crossed plane image prop symbols. I have tried using modelled plants but it makes the Vectorworks and IFC files far too heavy. Laura
The dialogue box says 'press a keyboard letter to go straight to that part of the list' but nothing happens when I do so. Laura
I would like to be able to create custom railing panels. This is one that I have bodged together by making a custom 'post' that is actually a panel and then using a frame to form the post. Also 'send to surface' so that I don't have to laboriously set the correct heights at the beginning and end of each run. Laura
Jesse, Thanks very much, that works just as I wanted it to. Much appreciated Laura
Hi Jesse, Thanks very much, I would like this option please - "add lines of code to set all the attributes of the selected items to be By Class" I don't normally have 2D attributes by class (it is only fill and pen attributes that I need here) it's just quite handy to have the site modifiers by class, then I can see which ones I've finished. Laura
Great, thanks Jesse that works perfectly and will save me a whole load of time. Just to make it a bit more complicated, when I do the change manually it gives me an option to change all attributes to the new class defaults, it that something that could be written into the script? Laura
Is there a way of making a similar tool that would move a selected object into a class (in this case Site DTM Modifiers) without changing the active class? I am using 3D poly modifiers and it's very time consuming to scroll dow through the list each time. Custom tool used to do things like this without any programming knowledge a long time ago. Thanks Laura
Thanks Haven't got all the levels yet so I think a site model with blanket level zero is in order.
Can anyone tell me why my plants are floating in their landscape area style? The more components I add the higher they float. Thanks Laura floating plants.vwx
Hi Mihail It seems like my colleague has solved the mystery. We exported using these settings (attached) and it worked. I had unchecked the export site model box on the grounds that I wasn't exporting the layer with the site model on, could that have been the problem? Laura
Hi Mihail Here is a small extract from the file, I have just included some hardscapes and landscape areas. The Architects are using Revit 2021. I sent a revit export but it had the same issue This is the latest from them: "I’ve attached a screenshot from the previous model (27/11/20) showing the IFC parameters I mentioned in the first email that enable material changes below." The previous model was the one that they could work with. Thanks Laura IFCtest.vwx
I have exported an IFC file and it opens in Solibri but the Architect, who is using Revit, tells me that it "won’t allow us to add on material properties, the model components seem to be made up of import symbols. As a result of this we’re unable to render the model as it comes out coloured grey" The objects are hardscapes and landscape areas, I can see that the hardscapes have nothing filled in under 'material' in Solibri. Could this be the issue? If so what IFC data maps to material? A file that i had sent earlier that was just extrudes made into symbols with IFC data attached was apparently fine and they could attach materials. I have tried sending an rvt file but it is very big and according the export will have no data, just geometry. Any help greatly appreciated. Thanks Laura
landscape area not aligning on site model surface
Laura Stone replied to tristanwel21's question in Troubleshooting
Thanks very much - worked perfectly Laura -
Thanks Tamsin I'll send it over. It is quite a big file so might have to cloud drop it. Laura -
Hi Tamsin I've checked both of those and the site model is set to respond to site modifiers on the layer that the landscape area is on and the landscape area is set to the site model layer. Funnily enough the layer that I accidentally moved it onto was not a layer that the site model was set to. When I moved it back onto the correct layer it went back to z=0. I guess I can put it on the 'wrong' layer to export IFC to the Architect but it is a bit of a pain. Laura -
Just had the same very frustrating problem, site model layer assigned and the texture showing up on the site model, but landscape area stubbornly sitting at z=0. I moved it onto the same layer as the site model and sent to surface, no joy. Went to move it back and accidentally moved it onto my retained soft layer (containing existing trees). Suddenly it moved into the correct place. Can't explain this, think it must be a bug. Laura
