When importing dwg files as reference something strange happens to drawing Z-coordinates. If I look the drawing form the side view (attached picture) the Z:0 seems to be moved a lot below where it used to be. But still for example if I draw a rectangle on a layer (with elevation 0) it will show up on the same level where the Z:0 used to be. Not where the Z:0 seems to be now?
I know that User origin changes the X,Y values and you can change the elevation per layer. But how to change the "global" Z coordinate of the drawing? I'm totally stuck here. What the hell is going on here??
lauripit
1 answer to this question
