Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
The Hamma
Fills in Top/Plan
I would like a way to turn of fills in Top/Plan projection, ideally in View ports. This would be convenient in making Electrical and RCP plans with out turning off the fills on the Floor Plan. Does any one have a solution that is not global?
Create a CLASS w/ attributes (fills.hatches, etc), then place all filled objects into that class(es). In your VP's, use the VP Class Overrides to change the attributes of each pareticualr class. This can be done a "per-VP" basis, IOW, you can change a class's attributes as desired for each VP. HTH's
