get siding to extend over foundation
The most accurate way to model siding is as its own "wall". This allows the siding to extend beyond the actual wall. . .as it would in real life. And has the benefit of providing the proper detail in section.
Challenge is door, window and other openings. I would place a cased opening in the siding "wall" and set the casings to 0. The exterior casings on the windows and doors will need to accomodate the siding thickness. . .just as they will have to in construction.
View your wall (siding wall?) in elevation (front or side view) and use the 3D editing tool to adjust the bottom line (including adding points) to follow grade.
Good luck,
