Silje Jessica Posted April 20, 2022 Share Posted April 20, 2022 Hello, I am working on a project where I need to push 1000's of these buckets into a wall, and we will change the location often. Is there a script that makes the wall 'elastic' or will automatic not show it through the bucket (3D symbol)? Quote Link to comment
zoomer Posted April 20, 2022 Share Posted April 20, 2022 I assume it could work with a Symbol attached to a Wall. I think you need to create your own cut geometry in the Symbols cut layer. Would have the advantage that the Wal stays a Wall and that you should be able to relocate the Buckets (one at a time only ?). 1 Quote Link to comment
bcd Posted April 20, 2022 Share Posted April 20, 2022 8 hours ago, zoomer said: I assume it could work with a Symbol attached to a Wall. Yes a regular Symbol is the way to go. Create a Symbol of the bucket Make sure the Symbol options are set to Insert in Walls Edit the Symbol's 3d Wall Hole Component Place a 'solid' bucket there. happy wall bucketing! 2 Quote Link to comment
