ramps in vectorworks 12
mwysolme
Without more description, it's hard to know exactly what sort of ramp you're making. If it were me, for most ramps I can think of, I'd use the Roof Plane tool. This way I could use the Object Info Pallet (OIP) to adjust slope and size. . .from either a 3D or 2D view and it would be correct for both.
In future postings, perhaps you could list your OS (type and version) as well as the version of Vectorworks you'r using.
Good luck,
If your ramp is truly rectangular in plan view, then here's what I suggest: 1) switch to a side view 2) Draw the triangle shape (section) of the ramp) 3) Still in side view, extrude the triangle to 4' (the width of the ramp). 4) Switch back to top/plan view and move the ramp into its propoer position.
As an alternative you could folow Travis' advice and use the ROOF FACE tool.
Hope that helps.
