mwysolme
    16
Everything posted by mwysolme
  1. I have 11.5 installed and when I upgraded to 12.5 none of my spotlight resources show up in the resource browser. What can I do to migrate this items over? Thanks
  2. I just had to re-install vectorworks. In 11.5 my spotlight worked fine. Now I don't have any of my lighting objects in 12.5. Any thoughts. Did i miss installing something.
  3. I have added the truss. have it hanging in the air. How to I determine weather the light hangs from it or sits on top of the truss. It seems that when ever I add the light it just under hangs.
  4. sorrie im using vectorworks 12 and its just a ramp that is 7' long and 4' wide that starts on the ground and ends at 1' off the ground. I hope that helps. thanks
  5. im trying to create a custome ramp. i can make in 3d view but as soon as i go back to my ground plan it looks wrong and distroted...any advice?
  6. i am trying to create long vertical chains, i dont want rollar chain, i want regular chain any idea how to create it?
  7. I am trying to create lighting positions, i was able to use stock pipes ie 50' and put a light on it and give it a z height no problem so that when i clicked the object info for the pipe it would say that 1 light was on it, as soon as i try to create my own lighting position, a pipe to the length i need, it works fine i can put a light on it and it tells me its there but i cant give it a z height, i type in 26' and it goes right back to 0 any ideas?
  8. mwysolme
    two-Fer
    i am trying to gang/ two fer two lights together, is there anywith to get the legend info to appear as if its comming out of the bottom of the line joining the two instruments insted of each light and haveing the same info twice
  9. dont respond to this, i figured it out
  10. I am new to vectorworks and spotlight, for a class assignment we are trying to reproduce a version of our light plot done in a much older version of spotlight, right now i am trying to add info to each instrument so that it displays on the plot, i am trying to use the lable legend manager, but when it opens and i click new a list of different lables are there but i cant click any of them what do i need to do
  11. how do i convert it from the cornice that comes out of the resource broswer to a 3d polygon
  12. the cornice molding came right out of my resource browser under wall accessories
  13. i am using fancy cornece to create molding around the top of my walls. and am trying to add texture to it using render works
  14. i am new to vectorworks, so i need all the info i can get so the most details i can get to solve this problem is the best
  15. i added stock molding from my resource browser and am trying to add wood texture using renderworks texture, i added the texture file to my resourse broswer and on the object info page of the modleing i selected the wood texture, but there are no options after i select. and it just renders in grey....i was able to do it before and cant figure out what im doing wrong. i can add texture this way to walls that i create, but not this molding...any ideas?
