Siradrad Posted March 27, 2022 Share Posted March 27, 2022 Anyone have any ideas how one might edit a CMU wall to have geometric openings like breeze block? Quote Link to comment
Jeff Prince Posted March 27, 2022 Share Posted March 27, 2022 You can make a texture with an alpha channel to simulate this appearance. If you need actual geometry, it is easiest to model a block as a symbol and duplicate. Quote Link to comment
Siradrad Posted March 28, 2022 Author Share Posted March 28, 2022 Thanks Jeff, I was thinking this might be the way to go. 1 Quote Link to comment
Matt Overton Posted March 28, 2022 Share Posted March 28, 2022 Transparency works if you don't get to close as you get 2 3D planes a wall thickness apart each with the alpha image of the block. Our local supplier had BIM models of the blocks so no need to self model but also super heavy in the scene. Quote Link to comment
