MHBrown Posted January 26, 2022 Share Posted January 26, 2022 Does anyone know how to create a Renderworks texture that will start opaque and gradually become transparent? I like to have the floor of my exhibition renderings gradually fade away into the background color and the best way to do this is with a gradient map in most rendering apps. Usually you build a black to white gradient in Photoshop and place it in the texture map design somewhere. I'm using VW2022 on a Mac running Catilina, although I'm going to upgrade soon to a version which I can remember how to spell. Thanks for any help! Mike Quote Link to comment
Guest Wes Gardner Posted January 26, 2022 Share Posted January 26, 2022 @MHBrown gradients applied to 2D objects can do that but I'm not sure textures applied to 3D elements can...obviously textures for glass or water can have some transparency but I don't think you can get them to fade from opaque to transparent... Can someone prove me wrong? Would be cool... Wes Quote Link to comment
mjm Posted January 26, 2022 Share Posted January 26, 2022 (edited) 8 hours ago, MHBrown said: Does anyone know how to create a Renderworks texture that will start opaque and gradually become transparent? I like to have the floor of my exhibition renderings gradually fade away into the background color and the best way to do this is with a gradient map in most rendering apps. Usually you build a black to white gradient in Photoshop and place it in the texture map design somewhere. I'm using VW2022 on a Mac running Catilina, although I'm going to upgrade soon to a version which I can remember how to spell. Thanks for any help! Mike 3 hours ago, Wes Gardner said: @MHBrown gradients applied to 2D objects can do that but I'm not sure textures applied to 3D elements can...obviously textures for glass or water can have some transparency but I don't think you can get them to fade from opaque to transparent... Can someone prove me wrong? Would be cool... Wes @Wes GardnerLike this? Just a quickie stab in the dark: Cube, with point source inside, with gradient PNG + alpha channel developed in PS, imported as texture with transparency set to Alpha Edited January 26, 2022 by mjm 3 Quote Link to comment
Guest Wes Gardner Posted January 27, 2022 Share Posted January 27, 2022 @mjm cool use of Photoshop...for those who can't afford PS, you can try Gimp...free, open-source... Wes Quote Link to comment
mjm Posted January 27, 2022 Share Posted January 27, 2022 (edited) 4 hours ago, Wes Gardner said: @mjm cool use of Photoshop...for those who can't afford PS, you can try Gimp...free, open-source... Wes Or Pixelmator or Affinity. Not free of course but cheaper than PS I am thinking about how to accomplish this task solely in VWX. Seems potentially doable. Edited January 27, 2022 by mjm Quote Link to comment
MHBrown Posted January 28, 2022 Author Share Posted January 28, 2022 Yes, that looks like you're on the right track. I'll use your advice and do a little more experimenting. I'm trying to make a ground plain that disappears as it moves to the horizon line. Thanks for the help! 1 Quote Link to comment
