_c_ Posted January 10 Share Posted January 10 Like many before me, I am struggling to get any kind of User Interaction work in custom plug-ins. This is Vectorscript-Python only, Vectorscript-Pascal works flawlessly. This affects routines like vs.GetPt, vs.GetPtLn, vs.GetPickObjectInfo, vs.TrackObjectN, etc.: there is no way to set global vars, and most attempts crash VW. I read over and over all posts in the present list, I cannot get it done. I am fairly new to Python, so first of all I ask: is anyone aware of a way to get above mentioned routines work in custom plug-ins? If yes, please let me know how. Otherwise, I'd like to file bug reports. Hopefully we can get a fix at one point, since this problem is recorded since Python was introduced in VW. There are two things discouraging users to switch from Pascal to Python: lack of user interaction support and weak code encryption. If we could resolve the first it would be great. Please @K.Lalkovski, can you help us there? Thank you _c_ Quote Link to comment
Antonio Landsberger Posted January 12 Share Posted January 12 Hi _c_, I can confirm: vs.GetPt doesn't work running it via Marionette Node in 2020 SP6, 2021 SP5 or 2022 SP2. But there is no crash at least. When I run the Node, vs.GetPt seems to be ignored. If this would work, you could do interesting things for sure. Regards, Antonio 2 Quote Link to comment
Vectorworks, Inc Employee K.Lalkovski Posted January 12 Vectorworks, Inc Employee Share Posted January 12 Hi _c_, I'll check why user interactions does not work. Regards, Konstantin 4 Quote Link to comment
Paolo Posted May 14 Share Posted May 14 I get vs.GetPt() working in an event driven plugin object (VW2022 on MacOS) with this trick: def PickPointCallback(pt): h = vs.PickObject(pt[0], pt[1]) if h != None: resultStatus, parmName, parmHand, parmRecordHand, wallHand = vs.GetCustomObjectInfo() if parmHand != None: #do your things with the picked object #at the end of the callback function call this vs.SetObjPropVS(kObjXHasCustomWidgetVisibilities, True) #plugin event loop theEvent, theButton = vs.vsoGetEventInfo() if theEvent == kObjOnInitXProperties: … elif theEvent == kObjOnAddState: … elif theEvent == kObjOnWidgetPrep: … #then in the button hit event, where the get point is called… elif theEvent == kObjOnObjectUIButtonHit: if theButton == buttonID_2: #set widget visibility to false vs.SetObjPropVS(kObjXHasCustomWidgetVisibilities, False) vs.GetPt( PickPointCallback ) #finally the reset event elif theEvent == kResetEventID: … # Without setting custom widget visibilities, calling vs.GetPt() crashes Vectorworks! 1 Quote Link to comment
