Joan Posted February 23, 2005 Share Posted February 23, 2005 Has anyone received this message when attempting to open Task Mangager in the Learning CD? This command is dependant on the document structure created by Model Setup and Create Standard Sheets. Please run these commands to intitialize the document before continuing. Quote Link to comment
mike m oz Posted February 23, 2005 Share Posted February 23, 2005 Before you can use the Task Manager you must first 'define' the project. The message is telling you you you haven't done this. Have a read of Chapter 3 of the Architect manual. Quote Link to comment
Jonathan Pickup Posted February 23, 2005 Share Posted February 23, 2005 yes, if you try to run the task manager before you have given a "structure" the the file, the Task Manager can't do it's job. it relies on the standard layers and classes created by the set up commands to be able to work. Quote Link to comment
Joan Posted February 23, 2005 Author Share Posted February 23, 2005 I understand that with a blank document I have to give "structure"; however, with a Learning CD, I lose the format already set in place. Any suggestions pertaining to this problem with the ARCHITECT LEARNING tutorial? Quote Link to comment
Jonathan Pickup Posted February 23, 2005 Share Posted February 23, 2005 i guess you could go though the set up utilities that the error message tells you to go though, then use that file for the exercise. Isn?t there an exercise file for you to use? Otherwise go on to the next exercise. I don?t use the task manager because I don?t like the file structure that the standard set up commands give to the file... My belief is that you should learn how to set up your own layers, classes, viewports and sheet layers so that you can make drawings that suit you and your drawing style. However good the programmer is for the standard cammands they can?t guess how you would set up a particular drawing for a specific project. Quote Link to comment
wv_vectorworker Posted February 26, 2005 Share Posted February 26, 2005 if they haven't used VW they probably have no idea how they can use classes, layers etc to set up drawings for projects. Quote Link to comment
mike m oz Posted February 26, 2005 Share Posted February 26, 2005 1. The second part of the Tutorial CD is about setting up a project, and therefore if they have viewed that part of the CD first they should understand what the purpose of the setup is and why they are doing it. 2. Having an understanding of how the drawing information is 'organised' (ie. layers and classes) is a fundamental pre-requisite to drawing capably. After all you wouldn't start teaching someone how drive a car without first making sure they undersood the fundamentals of how to control the car. Why should CAD be any different? Quote Link to comment
Jonathan Pickup Posted February 26, 2005 Share Posted February 26, 2005 before the Architect CD there are a series of foundation CD?s. These should show you how to set up a drawing (but maybe not a whole project) using layers and classes. I think that learning about layers, classes, viewports and sheet layers is so important I devoted over 100 pages to it in my Essential Manual. If you learn how to set up your drawings correctly then you don?t the standard set up command and you don?t need the task manager. Quote Link to comment
