Best way to label multiple LED wall of different sizes
2 hours ago, Paul S. Morrill said:
I have a drawing with multiple LED Walls  can I create a quick way to label them in a drawing
Basically pull the info from OIB?
size
pixel count
manufacturer
module count
etc.
The Landru Design version of that tool tracks everything you list, plus a few other things.  This version will also let you display everything except manufacturer (unless you use the Note field) in text blocks embedded in the given PIO instance.  See the link in my sig for more info.
  • Love 1
However, manufacturer and model info are in the OIP, so you could use a Data Tag to display that info in your drawing.
