shorter Posted November 16, 2021 Share Posted November 16, 2021 How many file formats or file types can we use to generate a site model/digital terrain model? Excel XYZ coordinate file, in csv or xls format DWG 3D points/loci 3D polygons Point Cloud Extract 3D loci from Point Cloud We have a script to convert 2D text to 3D loci, as a last resort, and there is the rather frustrating 2D polys to 3D source command. I particularly like the 'Modify by Record command' that 'can convert 2D polygons or polylines with attached record elevation data directly to 3D polygons at the proper elevation.' But what about other file formats, like OBJ, or 3DM? Quote Link to comment
Benson Shaw Posted November 17, 2021 Share Posted November 17, 2021 Ok, I did not try this possible workaround for objects imported from OBJ and 3dm files (but have wondered whether it would work) —- slice em’ with the Contour tool to create, well, contours. These file types import as meshes and therefore would likely create dotted rather than continuous “contours”, but maybe those could be joined via script, or converted to 3d polys or loci which could then be used as source data for DTM. or, maybe that’s just another stupid idea that won’t work (JASITWW pronounced “jaZITwuwu”) -B Quote Link to comment
shorter Posted November 17, 2021 Author Share Posted November 17, 2021 It would be handy to be able to extract 3D loci from any 3D form. 1 Quote Link to comment
