Onink Posted November 13, 2021 Author Share Posted November 13, 2021 (edited) For me, the 'get record field' node does the trick. But I have some issues: One I fixed: the record fields are strings and you need to convert the string to number with the math integer node. Then it works. Two: when I use a boolean as a recordfield type, the outcome is true or false. If I link this to an 'if' node, the outcome doesn't change after the if node. If I use a boolean node with the if node the output of the boolean is 0 or 1. So when I change the recordfield type to number, and use 0 or 1, I would expect the outcome would change, but that doesn't work too. Perhaps this will work with the math integer node, but I haven't tested this yet. How can I use the boolean fieldtype in a record with the if nodes? Get record field test v2020.vwx Edited November 13, 2021 by Onink Quote Link to comment
KingChaos Posted November 13, 2021 Share Posted November 13, 2021 What u want to input there? Which record? For me the project is canceled, because i cant manipulate the xg cabinet Name. The rest is done, if i can manipulate the cabinets name i am a vwx arcmage and i can clone cabinetstrings with a polyline rdy configured, connected to each Other parametrical, deactivatable and Named with cnc. Quote Link to comment
KingChaos Posted November 13, 2021 Share Posted November 13, 2021 What boolean? Quote Link to comment
Onink Posted November 13, 2021 Author Share Posted November 13, 2021 If you select the 2d symbool 'Dakkapel achterzijde' (Right side) you can select Rolluik as last in the data list. This is a boolean. This does not return a 0 or 1, but a true or false. There is only one record in there. 14 minutes ago, KingChaos said: For me the project is canceled, because i cant manipulate the xg cabinet Name. The rest is done, if i can manipulate the cabinets name i am a vwx arcmage and i can clone cabinetstrings with a polyline rdy configured, connected to each Other parametrical, deactivatable and Named with cnc. Nice job, it must have given you some headaches to get it fixed. Too bad you can't get the XG Cabinet renamed. If this could be possible it would open up al whole lot of possibilities. 1 Quote Link to comment
KingChaos Posted November 13, 2021 Share Posted November 13, 2021 You can use a value node, if it exists. ^^ Quote Link to comment
KingChaos Posted November 13, 2021 Share Posted November 13, 2021 (edited) 23 minutes ago, Onink said: If this could be possible it would open up al whole lot of possibilities. It Would be possible to Sketch a whole Shop interior in an hour, and it is changeable in 10 min to All u could change it. Edited November 13, 2021 by KingChaos Quote Link to comment
Onink Posted November 13, 2021 Author Share Posted November 13, 2021 That would be great. But that would also need a powerful computer I suppose. Quote Link to comment
KingChaos Posted November 13, 2021 Share Posted November 13, 2021 I got a hp z6 g4 Quote Link to comment
Onink Posted November 15, 2021 Author Share Posted November 15, 2021 I don't think that computer will have any problems... 1 Quote Link to comment
Onink Posted November 15, 2021 Author Share Posted November 15, 2021 On 11/13/2021 at 9:31 PM, Onink said: So when I change the recordfield type to number, and use 0 or 1, I would expect the outcome would change, but that doesn't work too. Perhaps this will work with the math integer node, but I haven't tested this yet. I used the math integer node and that works, so I'm good for now. But I still would like to know if there's a node that can make the boolean in the record field work with the if node. 1 Quote Link to comment
KingChaos Posted November 18, 2021 Share Posted November 18, 2021 Manuel, jann er nicht die Daten der Tabelle in die Datenbank schreiben? Die wird doch aktuell gehalten, oder? Quote Link to comment
