Mark Aceto Posted August 14, 2021 Share Posted August 14, 2021 The symbol has the data record intact but the House Rigging Points no longer attach it, even if I start from scratch. Quote Link to comment
Vectorworks, Inc Employee jcogdell Posted August 17, 2021 Vectorworks, Inc Employee Share Posted August 17, 2021 I will make an enhancement request, this is happening because the house rigging point tool converts the symbol into a parametric object which then blocks the record being visible in the data pane. If you ungroup the hanging point object after insertion the data record will become visible, however this will break the house rigging point object and convert it back into a symbol From my understanding this is the default behavior in Vectorworks whenever a symbol is converted to a parametric object by a tool and the few exceptions to this rule (like lighting devices and trusses) have been specially engineered to allow specific records to still be visible in the data pane Quote Link to comment
Mark Aceto Posted August 18, 2021 Author Share Posted August 18, 2021 13 hours ago, jcogdell said: I will make an enhancement request, this is happening because the house rigging point tool converts the symbol into a parametric object which then blocks the record being visible in the data pane. If you ungroup the hanging point object after insertion the data record will become visible, however this will break the house rigging point object and convert it back into a symbol From my understanding this is the default behavior in Vectorworks whenever a symbol is converted to a parametric object by a tool and the few exceptions to this rule (like lighting devices and trusses) have been specially engineered to allow specific records to still be visible in the data pane Thanks for the reply, Jesse. I could have sworn that the house rigging point PIO didn't block the record but maybe I manually added it the first time? This seems like another example of "works as designed" instead of "works as expected" behavior. Anyway, thanks for submitting the VE for this. Quote Link to comment
