VW2020 Double-Click Reshape Not Working on Lines
MINDI
Hi all,
I used to double click any line to reshape it, eg. I dragged the end point to extend. But since one day it is not working anymore.
Same issue happens when I try to change the dimension line. Before I could just drag the line to change the dimension, and the number changed accordingly. It is just not working anymore.
Anyone know how to fix it?
Thank you!
2 answers to this question
Make sure you are in either the second or third modes of the Selection tool.
The first mode is Disabled Interactive Scaling Mode which sounds like the condition you have.
You probably got the mode shifted by accidentally hitting the U key with the Selection tool active.
  • Like 3
