MultipleWays
Publish Naming Scheme
VW2021 Naming Scheme in Publishing > File Export Options doesn't seem to be working.  No matter which option I select, it will only publish with a file name as Sheet#SheetTitle
803093880_ScreenShot2021-05-05at11_02_22AM.thumb.png.3c7bcd51a18210675441f94caa10fb51.png
1 answer to this question
Hello @MultipleWays,
Thanks for the feedback! This is a known issue that should be fixed in the next service pack. In the meantime, there is a workaround by adding of brackets to the formula, for example "{Sheet#}", or by manually creating your formula using the "Insert Field" popup.
Sorry for the inconvenience!
Nikolay Zhelyazkov
