nick b Posted July 16, 2002 Share Posted July 16, 2002 Hello, I VWA user yet, so I was wondering if there is anyone creating construction documentation with VWA for homes built from S.I.P.'s(Structural Insulated Panels www.sips.org)? Typically shop drawings are created for the SIP manufacturers, the panels are cut in the factory and then shipped to the worksite. Does VWA help in creating these 2D panel drawings from a 3D model? If so, what would happen if the 3D model was changed -- would the 2D drawing change automaticly. Thanks in advance,Nick Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted July 16, 2002 Vectorworks, Inc Employee Share Posted July 16, 2002 There is currently no automated features in VectorWorks Architect for SIPS. However I know there are VW users out there doing SIPS projects. Hopefully we'll here from them on this topic. Quote Link to comment
jnr Posted August 10, 2002 Share Posted August 10, 2002 nick: I designed a 1800 sq. ft. house using sips that is currently under construction. I have relied on the traditional method of shop drawings for this project. That is, the fabricator was sent a hard copy of the set from which they were required to generate drawing from. I used the standard, (non-intuitive, poorly designed, cryptic) wall type tool to draw the project. I felt that forcing the fabricator to read the drawings makes them pay attention and not take your electronic information verbatim. I know this is an antiquated method, but so far it has worked. Quote Link to comment
Mark McCay-Moran Posted August 22, 2002 Share Posted August 22, 2002 I've used VW (not VWA) for several SIPs projects (as well as ICF, Contrete Tilt-Up, Pre-Cast Conc, steel and wood framing). Works OK. In my area it is standard practice for the fabricators to provide shop drawings (as is the case for just about anything that requires shop drawing approvals) not the other way around. Quote Link to comment
