Strings for Boolean values?
Stefan Bender
Dear developers,
is there an official SDK way to get the strings for the Boolean values "True" and "False"? They might be needed for tables or for displaying them in other contexts. What is the VW rule for these strings? Are they localized, uppercase, lowercase? I think it would be helpful to have some sort of consistent behavior and /or an SDK call to get the strings. I'm asking because I just got a bug report that is related to this (a plug-in of ours is trying to import values from a text file into a VW record field and it turned out that we had not specified how boolean values need to be spelled so the plug-in identifies the strings as "true" or "false").
Thanks,
I'm fairly sure the SDK doesn't have any built-in conversions for boolean strings. As a check, though, you can convert the string to uppercase and compare against "TRUE" and the localized true converted to upper case. Then return the localized value for true or false accordingly.
When you write to the field, use SetParamBool() to ensure the correct format. I believe that regular record fields are localized but PIO fields are not. I could be wrong, though.
Andy Dunning shared the following functions.  I hope he won't mind my sharing them here.
    FUNCTION Boo2Str(boo :BOOLEAN) :STRING;
        {Converts a boolean to a string.}
    BEGIN
        IF boo
            THEN Boo2Str := 'True'
            ELSE Boo2Str := 'False';
    END; {FUNCTION Boo2Str}
    FUNCTION TestBooleanStr(boo :STRING) :BOOLEAN;
    VAR
        str : STRING;
    {---------- NVW Function to Replace UprString ----------}
        FUNCTION UCase(str :STRING) :STRING;
        BEGIN
            UprString(str);
            UCase := str;
        END;
    BEGIN
        GetVWRString(str,'IP Resources/Strings/11000 *','3');
        TestBooleanStr := (UCase(boo) = 'TRUE') | (UCase(boo) = UCase(str));
    END; {FUNCTION TestBooleanStr}
The call to "GetVWRString(str,'IP Resources/Strings/11000 *','3');" is the arcane magic that I did not know about.
