SuperSparky Posted February 25, 2021 Share Posted February 25, 2021 I am having a problem moving a wall. I have a room in a home that used to be the garage for the house. So, it sits lower than the rest of the home. I have placed the second slab where it should go, but I cannot get the walls pulled down to meet the slab. I tried breaking the exterior walls away from the rest of the structure (like shown in the picture) thinking that might assist me in achieving it, but it doesn't. I can speck the walls the be the right height, but the start at 0 in reference the the original slab. How do I pull these walls down to meet the lower slab? Quote Link to comment
Pat Stanford Posted February 25, 2021 Share Posted February 25, 2021 Double Click on it to select the Reshape Tool and then use the Move mode to grab the handles and put it where you want it to be. Quote Link to comment
Vectorworks, Inc Employee TomWhiteLight Posted March 2, 2021 Vectorworks, Inc Employee Share Posted March 2, 2021 Pat is correct, if you didn’t want them to retain their height then you could use the move 3D command. Quote Link to comment
