A. Hurtig Posted September 6, 2001 Share Posted September 6, 2001 Is there a way to make base Architectural layers (such as partitions or structure) gray on sheets used for MEP, Electrical or PFP without having to "manually" reset the layers for printing? My objective is to be able to show (print) non-Architectural sheets (MEP, Electrical, or other non-architectural information) as highlighted or in the foreground with the base, Architectural context in the background. Quote Link to comment
Carl Burns Posted September 7, 2001 Share Posted September 7, 2001 This is sort of manual and probably exactly what you're referring to, but: You know about the "use layer colors" (document) preference? That's a simple, single switch to do what you're talking about. It obviously has a global (within file) impact though. A less fussy, somewhat dumber (dumb=good) option might be to simply cut/paste the required (plan) image as a group, assigning all of it the desired attributes (grey line color). Obviously it wouldn't update automatically, but for this use, that doesn't seem so bad. It seems that what we might all like would be to layer-link a set of layers into a target layer, and, while maintaining class colors for display/printing, display the layer linked layers as grey. I'm still baffled sometimes at the rules for displaying objects (what their attributes are) enclosed within other objects, as groups, symbols. Perhaps the above can already be done? Quote Link to comment
rcarch Posted September 8, 2001 Share Posted September 8, 2001 you could also edit your save sheet views to give the classes that those elements reside in a grayed visibility (same for layers) that way every time you go to the sheet view in question, everything would be the way you want it. hope that helps. ------------------ rich carrroll carrollarchitects Quote Link to comment
doug shaffer Posted September 10, 2001 Share Posted September 10, 2001 Hello - In my opinion, rcarch's description above is most logical. However, there are problems with this approach. Depending on the plotter/printer you are using, the 'grayed' background layers may not print dark enough. I have requested from NNA (for a couple of years now) the ability to assign a 'degree of grayness' to grayed layers. Perhaps this could be done using percentages - for example; 10% gray vs. 40%. We NEED the ability to make grayed back-grounds that change as as the floor plans are changed. Copying and pasting defeats the purpose of CAD. ------------------ d. s h a f f e r a r c h i t e c t Quote Link to comment
Robert Anderson Posted September 14, 2001 Share Posted September 14, 2001 The following script was posted some time back on the VectorWorks mailing list and is intended to give the user some control over the degree of gray in grayed layers: {************BEGIN VECTORSCRIPT***********} PROCEDURE GrayByLayer; { This script will traverse the active document and when it finds a layer whose display has been set to gray, it will set the layer color of that layer to a gray color defined by kGrayIndex. Then it sets the preference "Use Layer Colors" to TRUE and prints. Then it reverts to the original state of the document. CAUTION: This script saves the document in its original state! Note also that unlike the "gray layers" setting, this script will not automatically make the layer transparent, i.e., pattern fills in gray layers are preserved. } CONST kGrayIndex = 53; {this should be in the range of, say, 48 to 56} kBlkIndex = 256; VAR gLayerH,gVisLayerH :HANDLE; R,G,B :LONGINT; BEGIN DoMenuTextbyName('Save',0); gLayerH := FLayer; WHILE gLayerH <<> NIL DO BEGIN IF (GetLVis(gLayerH) = 2) THEN BEGIN layer(getlname(gLayerH)); ColorIndexToRGB(kGrayIndex,R,G,B); gVisLayerH := gLayerH; ShowLayer; END ELSE BEGIN layer(getlname(gLayerH)); ColorIndexToRGB(kBlkIndex,R,G,B); END; LPenFore(R,G,B); LFillFore(R,G,B); gLayerH := nextlayer(gLayerH); END; SetPref(11,TRUE); layer(getlname(gVisLayerH)); {This ensures that an invisible layer is not active} DoMenuTextbyName('Print',0); DoMenuTextbyName('Revert to Saved',0); SetPref(11,FALSE); END; RUN(GrayByLayer); {*************END VECTORSCRIPT************} Quote Link to comment
Eric Chenault Posted September 23, 2001 Share Posted September 23, 2001 What if the Saved Sheets macros could actually have different class and layer colors set there also (not just visibility), so a MEP drawing would have all MEP classes as black (for example), and a drawing for another discipline would have all MEP classes as a grey (selected from the color picker). I currently use layer colors for all of this, but it does mean changing layer colors every time a different setup is required. ------------------ Eric Chenault Lighting Design eric@ecld.net Quote Link to comment
