I can't modify door size in Object Info. How can I get this work? Thanks.
What version of Vectorworks? If you have Fundamentals, I don't believe that it contains the Door Tool, so you can't modify Door objects, but you can view them.
If you have a Door that uses a Door Style,
it may be possible that certain Settings of your Door Instance in Drawing
are locked by the Style.
So you need to do the edits in the Door Style instead.
Or if you want to edit that value individually per Door Instance, you can unlock
that value in Style, to get access to change for each instance in OIP separately.
Oh No. I just purchased Fundamentals and worked on it at my previous job. I could always modify the door. This is horrible. Do I have to build my own symbol? Thanks so much for your help.
I just went through the feature comparison. The Door tool was not part of the default workspaces in VW2016-2018 (I did not go back further than that), but could be added to a workspace. In VW2019, 2020, 2021, it just shows as not being part of fundamentals.
If you need it, you will have to upgrade. VW is usually good about letting you get full value as a trade up. Unfortunate that you will have to spend more.
Sorry.
Thanks so much. You are awesome. Have a great day/night wherever your are!
