tismacfan2 4 Posted September 26, 2020 I am creating a plug-in where certain text should appear in an arrow, and in which I can adjust certain text elements via the info palette. Only I can't manage to get the text parts that I have to fill in one after the other via the info palette. Now everything is written under each other. someone an idea how to change my script please? This is my script Procedure Ventilatiepijl; VAR eventID, eventMessage : LONGINT; pl,pb,a,b:REAL; t1,t2,t3,t123:STRING; ts:INTEGER; h:HANDLE; BEGIN BEGIN h:=FSActLayer; ts:=PSize; PushAttrs; t1:=Pnummer; t2:=plengte; t3:=pdebiet; pl:=ppl; pb:=ppb; TextFont(GetFontID('Consolas')); TextFace([]); TextSize(ts); TextFlip(0); TextRotate(0); TextSpace(0); TextJust(1); TextVerticalAlign(5); TextOrigin(0,0); t123:=Concat('Invisivent Air Basic 62m3/u.lm,',t1,'=',Chr(13),'=',t2,Chr(13),'',t3,Chr(13)); BeginText; t123 EndText; begin; Poly (0,0, pl,0, pl,-8, pl+20,12, pl,32, pl,pb, 0,pb ); end; PopAttrs; END; End; Run (Ventilatiepijl); Thanks for the help Quote Share this post Link to post
Pat Stanford 1,540 Posted September 26, 2020 The CHR(13) are Carriage Returns (CR) and move the text down to the next line. If you want it all on one line, take out the CRs. Quote Share this post Link to post
JBenghiat 355 Posted September 26, 2020 I think the problem is with TextSpace(0). This sets the line spacing to 0, so all the lines will lay on top of each other. 1 Quote Share this post Link to post
Pat Stanford 1,540 Posted September 26, 2020 Thank you Josh. I read the question backwards, thinking that tismacfan2 was getting multiple lines of text when only one was desired, rather than the intended meaning of the multiple lines of text are overwriting ("on top of") each other. Quote Share this post Link to post
tismacfan2 4 Posted September 27, 2020 Hallo Pat That was indeed my problem and by removing the cr I get what I wanted to achieve. Learned something new again. I can also use Jbenghiat's tip in the future. Thanks for the quick reply. Quote Share this post Link to post
