TKA Posted September 1, 2020 Share Posted September 1, 2020 I am setting up more elaborate wall types. Similar to Batt insulation I am using tiles for various items, one thing I unable to control is the scaling, for example if I have a stud 2x4 and I have a tile set with actual stud dimensions it shows scaled in the wall, it seems like 6" width fills the wall regardless of the wall thickness anything else is off. Is there a way to control that? Quote Link to comment
Pavol D. Posted September 1, 2020 Share Posted September 1, 2020 Have you tried Tile's 'Settings' (Fit to Wall option) under 'Edit' tile resource? Quote Link to comment
TKA Posted September 1, 2020 Author Share Posted September 1, 2020 yes, it doesn't work, meaning the only way it works at all is if I have the settings you posted but doesnt resolve scaling issue. Quote Link to comment
TKA Posted September 1, 2020 Author Share Posted September 1, 2020 here is a mystery bounding box highlighted in red as I move cursor above it, its actual 6" tall and it affects the tile spacing Quote Link to comment
TKA Posted September 1, 2020 Author Share Posted September 1, 2020 never mind, I had a invisible object causing it. Quote Link to comment
