Roger Webster Posted August 24, 2020 Share Posted August 24, 2020 I am creating some gravel areas in a garden using the hardscape tool and applying the gravel pavement slab style. The gravel wearing course does not render, only the bedding and sub base. The decomposed granite style has the same problem but other styles work fine. What am I missing? Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted August 24, 2020 Vectorworks, Inc Employee Share Posted August 24, 2020 Can you post a file with the Hardscape in please Roger? Quote Link to comment
Roger Webster Posted August 24, 2020 Author Share Posted August 24, 2020 Hi Tamsin I made a test file and they work fine there. But not in the actual file I'm working on. I also tried copying and pasting from the test file to the current file but the wearing course still doesn't render. If I make a simple hardscape object in my file just using the gravel render that works Quote Link to comment
jeff prince Posted August 25, 2020 Share Posted August 25, 2020 (edited) @Roger Webster It's pretty hard to diagnose your problem without a sample file illustrating the problem. I've seen this issue many times and it usually has something to do with classing or the "hardscape settings" used to create the hardscape. Also, check the thread linked below and see if any of that resolves your issue. Edited August 25, 2020 by jeff prince 3 Quote Link to comment
