The Hamma
Script to class Sheet Layer objects
Posted (edited)
This a global script that affects all sheet layers.  It classes all objects on sheet layers as follows.
Viewport Drawing labels to class = Sheet-Label
Viewport Annoatations to class = Sheet-Anno
Viewports and sheet items = Sheet-Main
Redlines remain on Notes-Redlines or A-ANNO-REDL
All classes listed above are turned on on all viewports.
This Python Script may be freely distributed. No warranty provided.
Use at your own risk.
David Hamer, 2020 revision 07-31-2020
# collect handles of selected VPs on active layer
def GetHandle(h):
	if vs.GetObjectVariableInt(vs.GetLayer(h), 154) == 2:
		if vs.GetObjectVariableString(h, 1166) != 'Redline Object':
			vs.SetClass(h, 'Sheet-Main')
		if vs.GetTypeN(h) == 122:
			hVP.append(h)
ACName = vs.ActiveClass()  # Record name of active class
ClassCount = vs.ClassNum()  # determine number of classes in drawing
vs.NameClass('Sheet-Main')  # Creates class if it does not exist and sets properties
if ClassCount + 1 == vs.ClassNum():
	vs.SetClFillFore('Sheet-Main',0,0,0)
	vs.SetClFillBack('Sheet-Main',0,0,0)
	vs.SetClPenFore('Sheet-Main',65535,65535,65535)
	vs.SetClPenBack('Sheet-Main',65535,65535,65535)
	vs.SetClFPat('Sheet-Main',1)
	vs.SetClLSN('Sheet-Main',2)
	vs.SetClLW('Sheet-Main',10)
	vs.EnableCLDropShadow('Sheet-Main',False)
	vs.SetClUseGraphic('Sheet-Main',True)
vs.NameClass('Sheet-Label')  # Creates class if it does not exist and sets properties
	vs.ShowClass('Sheet-Label')
	vs.SetClFillFore('Sheet-Label',0,0,0)
	vs.SetClFillBack('Sheet-Label',0,0,0)
	vs.SetClPenFore('Sheet-Label',65535,65535,65535)
	vs.SetClPenBack('Sheet-Label',65535,65535,65535)
	vs.SetClFPat('Sheet-Label',1)
	vs.SetClLSN('Sheet-Label',2)
	vs.SetClLW('Sheet-Label',28)
	vs.EnableCLDropShadow('Sheet-Label',False)
	vs.SetClUseGraphic('Sheet-Label',True)
vs.NameClass('Sheet-Anno')  # Creates class if it does not exist and sets properties
	vs.ShowClass('Sheet-Anno')
	vs.SetClFillFore('Sheet-Anno',0,0,0)
	vs.SetClFillBack('Sheet-Anno',0,0,0)
	vs.SetClPenFore('Sheet-Anno',65535,65535,65535)
	vs.SetClPenBack('Sheet-Anno',65535,65535,65535)
	vs.SetClFPat('Sheet-Anno',1)
	vs.SetClLSN('Sheet-Anno',2)
	vs.SetClLW('Sheet-Anno',10)
	vs.EnableCLDropShadow('Sheet-Anno',False)
	vs.SetClUseGraphic('Sheet-Anno',True)
vs.NameClass(ACName)  # Return active class
hVP = []
vs.ForEachObjectInLayer(GetHandle, 0, 2, 1)
# Traverse into the annotations group of selected VPs and set classes
for VP in hVP:
	vs.SetVPClassVisibility(VP,'Sheet-Anno',0)
	vs.SetVPClassVisibility(VP,'Sheet-Label',0)
	vs.SetVPClassVisibility(VP,'Sheet-Main',0)
	vs.SetVPClassVisibility(VP,'Notes-Redlines',0)
	vs.SetVPClassVisibility(VP,'A-ANNO-REDL',0)
	anno = vs.GetVPGroup(VP, 2)
	h = vs.FInGroup(anno)
	objs = [h]
	h = vs.NextObj(h)
	while h != vs.Handle(0):
		if vs.GetObjectVariableString(h, 1166) == 'Drawing Label':
			vs.SetClass(h, 'Sheet-Label')
			vs.SetLWByClass(h)
			vs.SetFPatByClass(h)
			vs.SetLSByClass(h)
			vs.SetFillColorByClass(h)
			vs.SetOpacityByClass(h)
			vs.SetPenColorByClass(h)
		else:
				vs.SetClass(h, 'Sheet-Anno')
				if vs.GetTypeN(h) == 11:
					gobj = vs.FInGroup(h)
					while gobj != []:
						vs.SetClass(gobj, 'Sheet-Anno')
						gobj = vs.NextObj(gobj)
		h = vs.NextObj(h)
Edited by The Hamma
