ules Posted December 8, 2005 Share Posted December 8, 2005 When I click on Final Quality Renderworks to render a file I always get the message the application has unexpectedly quit. I have deleted Vectorworks, Renderworks and all references to them and reinstalled them but still I get the application unexpectedly quitting on me. I am on 0S 10.3.3 and have at least 1 gig of memory and dual 1.25 processors. Incidentally it does not do it on all files but large files it unexpectedly quits. Any help would be greatly appreciated. Many Thanks!!! Quote Link to comment
CipesDesign Posted December 8, 2005 Share Posted December 8, 2005 Most likely there is a specific object in these files that is corrupt and is causing the crash. The best way to trouble shoot this is to try to render one layer at a time (not links or model views) to determine where the object(s) are. You might also want to contact NNA Tech Support. Sometimes if you send them the file they are able to find the problem. I know this is a frustrating problem, and I wish you luck. Quote Link to comment
islandmon Posted December 9, 2005 Share Posted December 9, 2005 Agree with Cipes ... bad object or artifact ... or Legacy Tool PIO lurking ... kernel panics due to NullVertices or something ... bad object ID ... begin by checking each Symbol, Font, and Object... per Cipes ... Quote Link to comment
Guest Posted December 9, 2005 Share Posted December 9, 2005 ules, I strongly recommend updating to OS 10.3.9 first. After updating the OS, please run disk utility to verify and repair disk permissions. After this has completed, please let me know if the crashing persists. Quote Link to comment
ules Posted December 15, 2005 Author Share Posted December 15, 2005 It can render it fine on my laptop.? My laptop is the same os as my G4 ? OS Panther and uses less memory. However I just deleted some of the objects in that file (as I only have got one layer!) and it rendered the rest of it, perhaps some objects are fine with my laptop but recognizes it as a bug in this computer. I had rendered different objects separately to see what was the culprit and reckon a sweep object (which is a pen) is causing it to quit (even though I had redraw it and simplified it). However, it only quit when I try to render it in final quality and not fast render with shadows. I have noticed with a few other larger sized files it quits unexpectedly. The spec of the machine is not an issue at all! Would it be worth my while doing a verify/repair permissions on my G4? Please Help!! Many Thanks Quote Link to comment
islandmon Posted December 16, 2005 Share Posted December 16, 2005 The update from 10.3.3 > 10.3.9 is a free comboupdate well worth the effort and Katie's sage advise should never be ignored. ComboUpdate10.3.9 Quote Link to comment
ules Posted December 19, 2005 Author Share Posted December 19, 2005 Many thanks for the advice I shall give it a go and let you know the outcome. Quote Link to comment
ules Posted February 6, 2006 Author Share Posted February 6, 2006 Hi there After I installed the combo pack update, it screwed up a few things up on the OS. System preferences will not open up and when I click on the Vectorworks folder in the Applications directory I have the spinning beach ball of death. Also when I have dragged it to the dock it wont open. Vectorworks only opens when I double click on a Vectorworks file. Please note that I am an IT guy who has been trying to help out a user who has had issues with it. When I logged in as Administrator. I can get to the Vectorworks folder no probs but I cannot open system preferences and have tried various solutions to this but no joy. Should I just rebuild the users machine with 10.3.9 and go from there? Quote Link to comment
islandmon Posted February 6, 2006 Share Posted February 6, 2006 RUN Disk Utility to check for File & Permission issues. Quote Link to comment
ules Posted February 7, 2006 Author Share Posted February 7, 2006 I did that but no joy. I think rebuilding is the only soloution. Quote Link to comment
