fuberator Posted May 7, 2020 Share Posted May 7, 2020 (edited) Hi 1. Is it possible to dynamically calculate a subtotal (count*price) for each of my summarised items? 2. How can I add a string to my sums, something like: =SUM(D2) + "total $ " and =SUM(E2) + "total lbs " Edited May 7, 2020 by fuberator Quote Link to comment
Pat Stanford Posted May 7, 2020 Share Posted May 7, 2020 Subtotal should just be a formula in D2 of =B2*C2 D2 and E2 will already have the Sum, so in a cell outside of the database row you should be able to enter a formula like: =Concat(D2, ' total $') =Concat(E2, ' total lbs') Quote Link to comment
fuberator Posted May 8, 2020 Author Share Posted May 8, 2020 (edited) Hi, That does not give me the individual subtotals, i dont understand the result at all. Am i doing it in the wrong place (directly in the selected header)? Edited May 8, 2020 by fuberator Quote Link to comment
Pat Stanford Posted May 8, 2020 Share Posted May 8, 2020 In the Subtotal Column make sure the Sum Values check box is set in the pull down menu. Quote Link to comment
fuberator Posted May 10, 2020 Author Share Posted May 10, 2020 (edited) yep that was it for the sum. thank you! Still no luck with the concat command. I cant seem to get it accepted as a formula Edited May 10, 2020 by fuberator Quote Link to comment
Pat Stanford Posted May 11, 2020 Share Posted May 11, 2020 I think you need to use semicolons between the parameters in the concat. I didn't pick up on your using commas (,) as your decimal point versus the period (.) we use in the US. =Concat(D2; ' total $') Quote Link to comment
