trashcan Posted May 7, 2020 Share Posted May 7, 2020 Is there a way to trim a 3D object? It's a series of groups with thousands of 3D polygons and other meshes (imported DXF). Essentially I'd like to apply a Clip Cube to the most parent group. Not for necessarily for Sheet Layers but in the design layer. Is that possible? The practical application is that we are building a section of an object and I need to work with in 3D not just in sheet layers. Quote Link to comment
0 trashcan Posted May 7, 2020 Author Share Posted May 7, 2020 Worth mentioning that the 2D split tool (second mode) seems to be a pretty good solution. Not getting the exact results I want but it'll do in a pinch. Quote Link to comment
0 Hans-Olav Posted May 7, 2020 Share Posted May 7, 2020 You can also try the clip tool, inclusion mode. I would test in a copy of the file (-; Quote Link to comment
0 trashcan Posted May 7, 2020 Author Share Posted May 7, 2020 @Hans-Olav no dice with the Clip Tool, inclusion mode. The object is a combination of Subdivisions and 3D meshes. What ended up working decently was creating a 3D box guide and then using the 2D split view from the left, right, front, and top until all that was left was my desired bits. The only problem I've run into (and can't seem to solve) - is that while the subdivisions trims very nicely, but the 3D meshes are pretty torn up. I suspect because they are empty pieces and not true solids (?). If I convert them I just end up with tons of incredibly unsmoothed polys which looks pretty bad, so I've left it as a 3D mesh. Any ideas on that? Quote Link to comment
0 Hans-Olav Posted May 7, 2020 Share Posted May 7, 2020 I'm not sure. I guess 3D mesh is the best option. Sometimes I have had luck with "add solids" prior to cutting but it depends how the geometry has been made. 1 Quote Link to comment
0 trashcan Posted May 7, 2020 Author Share Posted May 7, 2020 Yeah it's an imported DXF so it comes in a little nasty. Waiting for the client to finish remodeling in VW so this is really just a stop gap anyway. Quote Link to comment
trashcan
5 answers to this question
