RubenH Posted December 5, 2005 Share Posted December 5, 2005 Now the 2d reshape only works with click and drag. On VW 11.5 it wasn't that way, and was less difficult to reshape a 2d object using the data bar. It will be nice if we get that option again, and also with the lasso and box mode. RHF VW 12 Dual G5, OS 10.4.3 sorry for my english Quote Link to comment
propstuff Posted December 5, 2005 Share Posted December 5, 2005 Go to Preferences. there is a box to turn Click-Drag on and off Quote Link to comment
RubenH Posted December 5, 2005 Author Share Posted December 5, 2005 I refer to the 2d reshape tool. Not the preferences for all the tools. 2d Reshape, for polygons an polylines. I f you see on VW 11.5 when you reshape you only make a click on a point a nothing more, now you have to click and drag. Anyway Thanks. [ 12-05-2005, 04:12 AM: Message edited by: Mr. Gog ] Quote Link to comment
propstuff Posted December 5, 2005 Share Posted December 5, 2005 Hi again, I was talking about the 2D reshape tool. on my VW12 the 2D reshape tool works like it always has. If Click-Drag is turned off, I click once on a vertex and the vertex becomes "attached" to the cursor. Click again and the vertex is put down on the click point. No Dragging involved. With Click-Drag turned on, the button has to be held down after clicking and dragged to move a vertex. Nothing has changed for me. cheers, N. Quote Link to comment
RubenH Posted December 5, 2005 Author Share Posted December 5, 2005 Thanks for you response. I'm using a mighty mouse, maybe it's that. I have two machines with the same problem. One is using Vw12 Os X 10.4.3, the other is using OS X 10.4.3 Server, and it's the same for both. Thanks propstuff. Quote Link to comment
RubenH Posted December 7, 2005 Author Share Posted December 7, 2005 Ok i found something. When you use the 2d reshape there is no problem. But if you use first the lasso or box option with the 2d reshape, then it does not work anymore without click and grag. I think it's a bug. Quote Link to comment
The Hamma Posted January 3, 2006 Share Posted January 3, 2006 I have the same problem, but with added limitations. As stated above the problem shows up when using the lasso or box option, but also if you try to reshape a space with the "show Poly" option off. The other problem is that you can not reshape a space with the "show Poly" off as you could do in previous versions. -How long before we can expect a patch for all these bugs. Life as a Vectorworks User is getting annoying. [ 01-03-2006, 03:02 PM: Message edited by: The Hamma ] Quote Link to comment
