DDDesign Posted October 26, 2005 Share Posted October 26, 2005 When editing viewport annotations, I find I can't use the select all command, or even select all annotations (in this case dimensions) within a marquee. Is this a bug? Quote Link to comment
Travis Posted October 26, 2005 Share Posted October 26, 2005 Make sure you have your dimension class turned on at both the Sheet and Viewport settings. Quote Link to comment
DDDesign Posted October 26, 2005 Author Share Posted October 26, 2005 You're probably right, as I checked, and the dimension class-sheet visibility was turned off, and on in the viewport. However, a re-boot has also seemed to have fixed the problem. Strange... Quote Link to comment
islandmon Posted October 26, 2005 Share Posted October 26, 2005 Sometimes all it takes is to re-draw the Viewport screen view with a zoom in or out. Quote Link to comment
