alfresco
Stories
I am working on a residential project with 3 stories.   Walls and slabs are bound as expected.  I however have a garage that sits between the first floor and the second floor.  I am having troubles with the elevations for the garage.  The garage walls are unpredictable and I cannot achieve an 8 foot wall.  I seem to have the wall either bound to a fist floor of second floor  and corresponding stories.  I have tried a number of things such as creating additional design layers etc.  Any suggestions?
thanks,
lm
I would create some extra custom Story Levels and a special
Wall Style duplicate for the garage walls.
Thanks.  I have played around with an additional Garage Story with corresponding design layers and levels.  However, I still can not seem to resolve the problem.I think that it should be straight forward? Thanks,
lm
I believe you can't have a story that is between other stories - that is, they have to stack.  What I did in a similar situation is choose the story that was most applicable for the garage, and then adjust the Z-offset of the slab, and use AEC->Fit Walls to Objects... for the walls.  When things change (and they always do), I have to go through and adjust.
Yes, I meant creating extra Story Levels for Garage Wall binding,
but using the these on standard Stories of the house.
@alfresco Attached is a file with two buildings with different heights. I've also included a draft explanation.  If you go to Tools > Organization > Stories > Default Story Levels you'll see the set up involved. Notice how I've divided the levels between the two buildings. It DOES take a bit to get your head around it!
Wes
Two Buildings One File.vwx Multiple Buildings One Site final.docx
  • Like 3
Wes, Thank you very much for comments and attachments.  It was very helpful and I was able to come to a resolve.  Greatly appreciated!
