Thomas Wagensommerer 57 Posted October 30, 2019 (edited) "Widget Groups - Say goodbye to endless scrolling that creates a long and tedious workflow. We now offer widget groups in the Object Info palette that allow you to collapse and expand specific groups according to your preferences." Are these accessible by vector script? Where can I find documentation? Edited October 30, 2019 by Thomas Wagensommerer Quote Share this post Link to post
Peter Vandewalle 35 Posted October 30, 2019 They are available for Vectorscript and Python. But only on action-driven PIO's. You also need to add the parameters in the order they need to appear and with the necessary indents: You'll need some extra lines in the event section of the script. I also run a procedure in that part: "object_info_palet". This one holds some extra procedures to create the parameters and separators with the needed indentation. Hope this helps: CASE theEvent OF kOnInitPropertiesEventID: BEGIN bTest := SetObjPropCharVS(kWidgetGroupMode, Chr(kWidgetGroupAutomatic)); object_info_palet; END; ... function insert_separator(liID: integer; lsPIOName, lsParameter: string; liIndent: integer): integer; var lbResult: boolean; lsTmp: string; begin lbResult := GetLocalizedPluginParameter(lsPIOName, lsParameter, lsTmp); if lbResult then begin lbResult := vsoAddWidget(liID, 100, lsTmp); lbResult := vsoAppendWidget(100, liID, lsTmp, 0); vsoWidgetSetIndLvl(liID, liIndent); end; insert_separator := liID+1; end; function insert_parameter(liID: integer; lsPIOName, lsParameter: string; liIndent: integer): integer; var lbResult: boolean; lsTmp: string; begin lbResult := GetLocalizedPluginParameter(lsPIOName, lsParameter, lsTmp); if lbResult then begin lbResult := vsoAddParamWidget(liID, lsParameter, ''); lbResult := vsoAppendParamWidget(liID, lsTmp, 0); vsoWidgetSetIndLvl(liID, liIndent); end; insert_parameter := liID+1; end; procedure object_info_palet; var liID: integer; begin liID := 100; liID := insert_separator(liID, sPIOName, 'chGlobal', 0); liID := insert_parameter(liID, sPIOName, 'ObjType', 1); liID := insert_separator(liID, sPIOName, 'ch3D', 0); liID := insert_parameter(liID, sPIOName, 'DivSymbol3D', 1); ... end; Quote Share this post Link to post
