jg@swcm Posted October 25, 2019 Share Posted October 25, 2019 Hi all, Having recently downloaded VW 2020, I'm having trouble getting our workgroup folder to link up like we had it in VW 2019. It seems that the whole workgroup file structure has changed a little between VW 2019 - should I be linking to a different path than I did in VW 2019? Quote Link to comment
Pat Stanford Posted October 25, 2019 Share Posted October 25, 2019 There are a few things that have changed, but not a lot. Have you converted the files in the Workgroup to VW2020? If not that may be the problem. You might want to duplicate the workgroup to a new path, especially if you are going to be doing any ongoing work in VW2019. Quote Link to comment
zoomer Posted October 25, 2019 Share Posted October 25, 2019 There are 3 things to do. - Batch convert a copy of the old Folder to VW 2020 - Add your Workgroup path in Settings (I think the path has changed, does no more need the /Defaults at the end or so, you can find a hint in VW help) - Refresh Libraries Quote Link to comment
