Andrew Davies Posted September 1, 2019 Share Posted September 1, 2019 Hello all Does anyone know how to set a standard for Section Line styles? I usually make one - set it to show how I like (text size, section marker style etc) - then find myself having to set each parameter again after making a new one. I am sure there is a better way! Same question for Drawing Label - I never / rarely show the scale on a viewport so each time I add one I need to turn off the scale manually each time. Thanks in advance Andrew Quote Link to comment
markdd Posted September 1, 2019 Share Posted September 1, 2019 Maybe you’ve tried this before, but the way I have done this in the past is to change the parameters in the Plug-in manager under Customise. It normally works well but the drawback is that when you update the service pack these mods tend to get over-written. In order for the change to “take” you need to purge any pertinent “special record formats” from the file. Quote Link to comment
Andrew Davies Posted September 1, 2019 Author Share Posted September 1, 2019 Thanks Mark I have never ventured into the Plug-in manager so that is new to me! Did have a play and couldn't get it to work though? I changed the parameters for the Section Line Marker (and drawing label) and it didn't seem to make any difference? Created new section viewports and no change Thanks though - will keep on fiddling! Quote Link to comment
markdd Posted September 1, 2019 Share Posted September 1, 2019 (edited) You need to do the "Purge" step to eradicate special record formats. Then it should work. I know it does on drawing labels because I've set it up before. Failing that, open a clean file and test it there. Hope that works for you! Edited September 1, 2019 by markdd Quote Link to comment
Andrew Davies Posted September 1, 2019 Author Share Posted September 1, 2019 (edited) That did the trick - thanks!! 😳 I should have read your post properly! Think I will do a wish list for this to be made a bit more user-friendly. Guess just remembering the previous settings would be a start Thanks again Edited September 1, 2019 by Andrew Davies Quote Link to comment
