I will I 1 Posted July 25, 2019 Why is it that only a hierarchical view is available in the class drop-down list of the object info palette? This was not the standard behavior prior to VW 2019. Constantly expanding lists to move an object to another class is becoming a major pain point for many in our office. Is there something we are missing to change this to a list view similar to the Navigation palette? VW 2019 SP4 Build 490894 Quote Share this post Link to post
Tamsin Slatter 467 Posted July 25, 2019 Tools > Options > Vectorworks Preferences, Session tab, and then Display classes in pop-up menus hierarchically. 1 Quote Share this post Link to post
TKA 26 Posted July 25, 2019 for some reason, additionally, I need to select next box below : "preserve...." too make it happen Quote Share this post Link to post
Tamsin Slatter 467 Posted July 25, 2019 2 minutes ago, TKA said: for some reason, additionally, I need to select next box below : "preserve...." too make it happen That is if you want to use the hierarchy, which I think I Will I does not. If you uncheck the option then the preserve button is grayed out. The preserve option will remember which folders are expanding and which are not, regardless of which menu you are using. Quote Share this post Link to post
