Bob Griffith Posted June 25, 2019 Share Posted June 25, 2019 Still using pre-parasolid VW 2008. Do both architecture and mechanical, but infrequently. Possible first 3D submittal from VW to CAM via Solidworks 2019 front end at CAM shop. Sample top/plan dxf conversion file submitted below. Pict of export panel also submitted below. Problem: Solidworks import sees top/plan as static 2D view without any apparent 3D properties. Meanwhile, this file imports back into a newly launched VW fully 3D functional. Please advise. Appreciatively, Bob 480-456-4049 grifco.slider.01.dxf Quote Link to comment
Jim W Posted June 25, 2019 Share Posted June 25, 2019 What other formats will they accept than DXF? STL may work depending on the kind of shape and type of machining they're doing. Quote Link to comment
Kevin McAllister Posted June 25, 2019 Share Posted June 25, 2019 (edited) A couple of thoughts - - try exporting while your file is in a 3d view, not top/plan view. - use the newest export version possible (for VW 2008 it should be newer than DXF 2000 / 2000i / 2002). - use DWG instead of DXF if at all possible. Kevin Edited June 25, 2019 by Kevin McAllister 1 Quote Link to comment
Bob Griffith Posted June 25, 2019 Author Share Posted June 25, 2019 Jim -- They seem to like AutoCad 2000 and can do IGES (which doesn't re-import back into VW cleanly for me), Step & X_T -- and of course SW native.. Kevin -- I'll try all, one at a time. Expecially the 3D view (your online help ticket guy also recommends that). Thanks guys. Let you know. Bob Quote Link to comment
Bob Griffith Posted June 26, 2019 Author Share Posted June 26, 2019 Final solution for me to export a valid 3D part file from VW 2008 to a particular fab shop's SW 2019. 1) Yes, import from a 3D view and not the top/plan view. 2) Remove all other assembly layers except for the subject part. 3) Export as IGES with the NURBS option selected. Thanks guys! 2 Quote Link to comment
