38 -
Everything posted by Jim W
Its been a few versions since I've had a chance to sit down and do some modelling and... YES!! A THOUSAND TIMES, YES!! Thank you to whatever engineers are responsible for this deliciousness!
Yup yup, the higher you set the number of undos, the slower things can go. Especially when you're working on complex multi-level container objects like Solid Additions or groups within groups within groups.
I know I heard discussion of how to make history based model objects much healthier than the older ones, but I never got to see the guts of what came out in 2020. I know they did have that top of mind in development talks. I always converted to generic solids as well before exporting for a 3D print, but that was needed less and less in the later versions. Since I don't use modeling software in my daily work now I haven't seen what 2020 can do in person. I'd have loved to be able to keep each history aspect for powerful editing later and I wanna see about trying out 2020 myself at some point! Maybe I'll take a college class and get a student license. 👨🎓
SEAN IM SORRY! I still lurk indeed! But I was by no means the best. The guys in tech support were miles ahead of where I had been when I was a tech, we built a lot of systems for sharing knowledge and discussion in my time there, they've got you. I was just possibly the noisiest member of support, lol.
For over a decade at Vectorworks I wished for and dreamed of a Dark mode and it came out just months after I left!! *Shakes fist at the cruel sky*
- 150 replies
- 13
There are a few things that have to be set up right to see Gobos in renderings, I'm pretty sure its covered here:
2020 Teaser Tuesday - List Browser Direct Editing - Vectorworks 2020
Jim W replied to JuanP's topic in News You Need
Oooooooh Single Sign On might be getting closer! -
Shop using SW 2019 cannot 3D render DXF export.
Jim W replied to Bob Griffith's topic in Solids Modeling
What other formats will they accept than DXF? STL may work depending on the kind of shape and type of machining they're doing. -
Export PDf was added to Fundamentals I think in 2018? It wasn't present in 2012 Fund I'm pretty sure. On Windows 10, I'm fairly certain you can just go to File > Print and then it should usually offer Microsoft Print to PDF as a printer choice. You might need Adobe Reader installed to see this, but I always have it so I'm not sure if that's the case. But thats just OS level, and nothing to do with Vectorworks itself. If it worked on Windows 7 but you don't see the same thing on 10, then it means you may have had a third party PDF utility installed and you might need to go get it again for your new machine.
If thats the case, the next time you look into a computer upgrade, you may want to invest in more RAM. Chrome is my favorite browser but it hogs a LOT of memory.
The stand price left me speechless. Not even height or rocker arm style adjustment.
You can mix resolutions, its very common. In some OSes you have to have both of them have the same scaling of the UI, but resolutions can be separate without issue. When it comes to Vectorworks, IF you mix resolutions, then your experience will be poor, as Vectorworks will have to pick the scaling of one monitor or the other which would make it look a mess on the other. I almost always have dual monitors at minimum in my workflow, but I use Vectorworks on a single display. Oh yeah. If you have the graphics power to handle it, its great. Much more room for the UI, the OS elements can be made smaller while still remaining clear. However, I do not wear glasses and have great vision. I have heard from many people with vision concerns that they didnt benefit as much from 4k because they couldnt tolerate the letters being as small as it was possible to make them.
So the Fundamentals guide had a bit of that: https://www.vectorworks.net/training/2016/getting-started-guides/fundamentals But these days for that kind of oganic shape, I'd recommend the Subdivision tool, it should be able to easily whip out a pool shape: Its changed a bit since then, but still close.
Vectorworks isn't allowed to, sadly. Cloud processes require creating a virtualized instance of the OS, and macOS does not allow that, even on it's own hardware. 😞 All Cloud Services instances are Windows because of this. That will hopefully change someday but last I heard it was up to Apple.
I personally prefer macOS as a daily driver as well. It's got some annoying bits, but quicklook and expose are still hard to really match even with third party extensions on Windows. I will say that OTHER than the annoying autoupdates, Windows 10 is quite well worked out now. I was a big Windows 7 proponent for a long time as I hated 8, but 10 has finally started down the path of improving things again. It's not a terrible time to switch, or to get a mid-range machine in the meantime and learn it slowly. I'd say the main considerations are cloud storage and account syncing solutions before a transition is made. EDIT: Forgot I found this little gem the other day, not AS good as Apple's quicklook, but its 90% of what I want it for on Windows: https://www.microsoft.com/en-us/p/quicklook/9nv4bs3l1h4s?activetab=pivot:overviewtab
With Apple, concern for price is just out the window. At this point, it's a heavy price you pay for macOS, but it still has it's staunch fans. It's hard to justify it specifically for Vectorworks since it works cross platform, but for people whose software or ecosystem is completely Mac, this fills the need of "I just can get enough out of an iMac" which has been the problem for Macs for some time. There was NO high end option that you didn't have to overspend on for included mobility or slimness. Now this entry is definitely upmarket and ultra high end, but to be fair they did have a huge hole in that segment. The main issue I'm happy looks to be solved is thermal throttling. iMacs and MBPs all had that issue and I'm glad to see they took it seriously. As for secondhand Mac pros, I suspect a lot of the 2009-era cheesegraters and 2013 trashcan models will become available but the price may not drop very much. I DO predict however that now that a new Pro is available, macOS will start dropping support for the older models much sooner. I would have liked to see some more reasonable 2999- level price points and configurations for it too, but now they have a platform that it's possible in. I guarantee that fancy rollcage, (WHEELS!) fans and machined facing isn't more than $600 on it's own, so they could decide to put more mortal silicone in there if they wanted to after this initial rollout. They only have policy stopping them now.
Came across this quote from Maxon: “Tapping into the amazing performance of the new Mac Pro, we’re excited to develop Redshift for Metal, and we’re working with Apple to bring an optimized version to the Mac Pro for the first time by the end of the year. We’re also actively developing Metal support for Cinema 4D, which will provide our Mac users with accelerated workflows for the most complex content creation. The new Mac Pro graphics architecture is incredibly powerful and is the best system to run Cinema 4D.” — David McGavran, CEO, Maxon Guess that means Redshift is coming to AMD more than it does that Apple and Nvidia are going to clear up this current driver incompatibility nonsense. Hmmm. But honestly, i'm just so happy to see what they're offering. Does it cost way too freaking much? Of course, but thats how Apple rolls. It was slightly- (Oh man I almost said the new Mac Pro was Slightly GRATING but even thats too much pun for me.) irritating that they effectively took credit for cooling and accessibility design thats been standard in gaming PCs for years now but I'm just so happy to see them stretch far in that direction that I'll forgive it. Still have to see how the support for these PCI devices pans out, but for Vectorworks its gonna be awesome regardless. Base specs for this thing should handle Vectorworks like a dream since it's still limited to one GPU at the moment. If folk have transitioned over to Lumion or Cinema4D though, they'll REALLY fly. Aaaaaaand if you're still gripping your old cheesegrater from 2010 tightly, its safe to say you got your investments worth out of the old machine, hehe. 5,999 to jump a decade into the future aint so bad.
I hopped into the stream late but... be still my nerdy heart... it looks gorgeous and powerful so far. WHEELS!
😀😁🤓 https://www.apple.com/apple-events/livestream/
Keynote is this coming Monday! Its still not looking super solid, even on the rumor mill side, but I still hold out hope for a significant upgrade to Apples Pro offerings: https://www.macrumors.com/guide/wwdc-2019-what-to-expect/ With all they're throwing into eGPU support, I have to guess that they plan a "Modular" Mac Pro to be upgradable with external modules, rather than giving users access to the gut directly like they last did with the cheesegrater Mac Pro tower. Fingers crossed.
Because of my new account, I get to vote for it AGAIN! Hehe:
Isn't it freaking DOPE!? In general, you CAN do texturing in Vectorworks and Lumion will show them just fine, but their library has more advanced textures and supports more types of layered shaders in materials than Vectorworks does. I found it was best leaving the geometry and assignment of material by class to the Vectorworks side, and then do replacement of textures, lighting, water, moving objects and custom texture mapping in Lumion.
You likely have added Light objects, but have them all turned off, so that disabled the Default Lighting that is included in files by default. You should be able to get around it by either enabling a Light object, or by going to View > Set Lighting Options and increasing the Ambient lighting value, which if my guess is right is near or at 0 for this file.
I agree strongly with this. Dual CPU hardware is quite pricey, so much so that you rapidly enter the territory of distributed rendering solutions being much cheaper.
So it worked REALLY well on a MBP if the GPU the MBP had included was already weak like the Intel options the 13" models had. But I saw very little change in actual performace when i added an external GPU to a MBP that had a decent GPU already inside it. The detriment you get to performance over thunderbolt 3 is minimal compared to older cords, but it still existed. Also, High sierra eGPU support is really rough, a LOT of manual poking can get you there if youre persistant, but it was a headache. Mojave compatibility was basically plug and play, but came with the limit to AMD cards only, and even then a small selection of them. That said, the new 15" MBPs have solid graphics choices for a laptop honestly, bringing in the 8core CPUs finally is a nice change as well. My work now has me on windows-only, but I still plan to keep an eye on the Silver Side.
