CETLV Posted May 16, 2019 Share Posted May 16, 2019 When setting an instrument onto the trussing, I attach one with auto attach, then duplicate array for most instruments because I do not like to convert to hanging positions. I try to keep the rigging and lx plot files in the same file if possible. The problem is that when you duplicate array it dupes the load id and you have to go through and change each instrument manually, is there a way to do this? or talks to get load ID in the numbering tool? Quote Link to comment
Vectorworks, Inc Employee klinzey Posted May 16, 2019 Vectorworks, Inc Employee Share Posted May 16, 2019 You should be able to simply run the "Reset Braceworks IDs" command and generate all new Load IDs. Quote Link to comment
