Hello Community!
This Saturday, May 30, from 9am – 12pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
zoeageorg
Vectorworks 2018 freezes glitches pauses when selecting objects, object info pallette slow to load
VW 2018
Every time I select an object such as window, wall or door, the programme freezes and takes ages to load the object info pallette.
The pallette is graphically glitching as it switches info.
The programme hasn't slowed down overall but this is slowing down the work!
9 answers to this question
It is also so slow to changed object info eg. Flip a door, change a wall thickness but using parameters in the object info pallette
Can you try undocking the Object Info Palette and then resizing it? If you work with the OIP undocked, is it still slow?
We did a lot of work to the OIP in VW2019 to make it more responsive. I am wondering if you would get the same result in 2019. Do you have a VW2019 license or can you try working in the trial for 2019 to see if it is any better?
@jblock still having this issue, now even worse.
vectorworks 18 not responding almost every time i select a window.
makes it so difficult to do anything!
Can you send me a direct message with your dxdiag.txt file so I can check your system configuration? Also, were you able to try using a trail of 2019 as a test?
Thanks!
