AFDesign
How to detect screen plane/layer plane?
Hi,
I'm working with a 2D path object plugin, and I'd like to detect if the path has been created on a screen plane or layer plane.
I tried this:
GetObjectVariableBoolean(handle, 1160);
using both plugin and path handles, but I always get the same result drawing in screen plane or layer plane.
Any advice is appreciated, thanks!
Andrea
Try using GetObjectVariableBoolean (handle, 651)  This should return True for a Screen Plane Object.
Also take a look at 650 which will return true for a 3D (Layer Plane) object.
Thank you Pat, I tried but I always receive the same result, using 650 and 651. Maybe it is possible to detect if the plane is horizontal or tilted?
Can you post a small sample file showing this issue. I just tested this before I posted.
I drew a line in layer plane. Duplicated it and converted to Screen Plane and then ran the following one-line script.
Message(Date(2,2),' 650:',GetObjectVariableBoolean(FSActLayer,650),' 651:',GetObjectVariableBoolean(FSActLayer,651));
I get reversed results between the Layer and Screen plane versions.
Sorry I'm using a 2D path plugin so I can't post a small sample. I will create a new 2d path plugin and I will try your advice on it! I will let you know if it works tomorrow.
Thank you!
GetPlanarRef doesn't work too. I created a new 2d path plugin and GetObjectVariableBoolean 650 and 651 works correctly, Pat!
I will check what's wrong in my code.
EDIT:
Now I understood. Variable 650/651 read if an object is 2D or 3D: a 2D object in a custom plane is detected as 3D. For this reason the new plugin I created works, because I only created a 2D polyline to test. But my plugin use the 2D path to create a 3D object, so I receive the same value because my object is a 3D object, in both screen or plan mode.
The only way to solve my problem is being able to read the custom plane tilt, but I didn't find a command for this.
(I found GetWorkingPlaneN but it isn't relative to an object)
Thank you all!
Edited by AFDesign
