Carl Burnett Posted May 2, 2019 Share Posted May 2, 2019 Hello, What have I switch off? or done wrong? Drawing is fine as soon as I fo to open GL or fast render the drawing goes into darkness apart from the glowing grass. The light options in view is at 100% Any ideas please? Thank you Quote Link to comment
Guest Paulo Ferrari Posted May 3, 2019 Share Posted May 3, 2019 @Carl Burnett Have you had this problem before? Or is it happening in this project? Regards Paulo Renan Ferrari Quote Link to comment
Carl Burnett Posted May 9, 2019 Author Share Posted May 9, 2019 Hi Paulo, sorry for delay been caught up in other stuff. Only in this project, I think. If change my background it makes it more visible but seems a bit weird I would need to do that. Thank youCarl Quote Link to comment
Jim W Posted May 31, 2019 Share Posted May 31, 2019 You likely have added Light objects, but have them all turned off, so that disabled the Default Lighting that is included in files by default. You should be able to get around it by either enabling a Light object, or by going to View > Set Lighting Options and increasing the Ambient lighting value, which if my guess is right is near or at 0 for this file. Quote Link to comment
