Carl Burnett
  • Content Count
    45
Everything posted by Carl Burnett
  1. Hello all, I have created a stage using the decking tool, I want to make the black floor reflective how do i achieve that? I have tried editing the vsBLKtexture but has soon as I add reflectivity the colour disappears. I would be grateful for any help to point me in the right direction. Thanks in advance Carl
  2. Hello All, I have a capture card that works with vision, I am having no problem using it with my Mac Book Pro. There is a problem when I try to use it with My Mac Pro (2.7 GHz 12-core Intel Xeon E5, 40 gig Ram, AMD Firepro D700 6GB) Vision and the file open fine with the select Video Source window open, when I press OK Vision quits!! Using same file and capture card I have no problems with my MacBook. I have updated to latest software on both machines. Any ideas would be appreciated. Carl
  3. Thanks bbudzon, MVR? not sure what the is, so i guess I'm not using it ūüôā Im just exporting straight out of VW to Vision. Thanks again for responding Carl
  4. Hello All, I have finally sorted a capture card that works with vision. I now want to know how I size or scale the screen or image so it doesn't duplicate as in the picture attached, you can see that the bottom of the image also appears at the top. Any help is appreciated. Thank you Carl
  5. Hello all, I have posted this in the entertainment part of the forum, thought it worth looking here. I am using GLP Impression X4 20's in my design. I position them in VW (1st pic) then when I export to vision (2nd Pic) this happens. I have found a work round which, is to rotate them in Vision. The problem with that is if I have to modify the VW file i'm back to square one! I am using 50 X4's so it takes a while. Is there a permanent fix? I also have issues with some instruments being upside down etc but that's not such an issue. any solutions/help appreciated. Carl
  6. Hey Gaspar, that worked, so it's a good work round, but if I make any mods to the VW file I'm back to square one. Thanks for the solution carl
  7. Thanks, i’ll give it a go tomorrow and let you know. appreciate your help. Carl
  8. Really? i have tried rotating by 90 degrees, is that what you mean?
  9. Hi everyone, Wondered if anyone had a solution to this orientation issue. I really need to start programming and this is obviously an issue! Thanks for your help. Carl
  10. Hi Paulo, sorry for delay been caught up in other stuff. Only in this project, I think. If change my background it makes it more visible but seems a bit weird I would need to do that. Thank youCarl
  11. Hello, I have my instrument summary (pic 1) create Viewport (pic 2) print to pdf and this happens (pic 3) why is this happening? how do I rectify the issue? If I exit view ports and go back to drawing if I click on plane/ Layer/screen it restores to complete summary. Thanks for any help?
  12. Hello Franco, It was in the Vectorworks Libraries in resource browser. if not it will be in VSS library. Carl
  13. Carl Burnett
    Darkness!
    Hello, What have I switch off? or done wrong? Drawing is fine as soon as I fo to open GL or fast render the drawing goes into darkness apart from the glowing grass. The light options in view is at 100% Any ideas please? Thank you
  14. Hi Klinzey, It is the GLP X4 Bar 20, 20 Channel
  15. Hello, Why is this happening? how can I rectify it? So I have GLP X4's I position them correctly in VW when I export to Vision they seem to position themselves randomly as you can see by the attached photos. I tried turning them by 90 degrees in VW you can again see how Vision positions them. VW and Vision are both 2019 SP3 Any ideas please? Thank you
  16. Hi, I am trying to render in Style or fast render. I render in openGl and everything looks fine, from there render in a style or fast render and lots os stuff goes missing.Please see attached. What am I doing wrong? I'm sure its simple but i'm lost. Thanks for any help
  17. Thats great thank you. Guess I should have remembered to save my prefs when I updated. duh
  18. Hello, I have just updated to SP3, where as the Lighting Pipe tool gone? it looks like VW has gone back to default settings is that part of my not seeing the pipe tool? Thank you
  19. Ok!! Got it. silly question, how do I de-sellect an object? Thank you
  20. Hi Kevin, Thank you for that. How do I do that? I haven't done anything with vision except use it to visualise VW. I have made a sphere in VW and exported to Vision. I'm trying to do a test run first. Thanks again for your help CB
  21. Hi Rob, I ment, how do I go about putting the genieric glow spheres in to my vision file? CB
  22. Hi Rob, thanks for this. I have only really use Vision as a pre vis for VW, I have added any Vision instruments is that easy to do? Also: is there and way of putting a mirror ball in vision? i'm guessing I would need to make it emit light rather that reflect it. Thanks again for your help. CB
  23. Hello I'm experiencing problems using SGM LB 100 led balls. when I make a string of them (52 ball) it takes forever to do anything with them (move, copy etc) I have tried modifying the symbol to take out everything other than the sphere to retain the lamp properties. I still have the same issue. What am I doing wrong? Is there another way to show a RGB festoon that will work in VW & Vision? thanks for any help CB
√ó
√ó
